EGR Valve Removeal
Old Jun 19, 2010 | 11:15 PM
04scurs's Avatar
04scurs
Question EGR Valve Removeal
I have my Int. Man. out but how do you get the EGR valve out of it? Also what is the torque for the bolts that bolt the oil cooler to the block?
Old Jun 20, 2010 | 08:16 AM
npccpartsman's Avatar
npccpartsman
remove the two bolts from the EGR valve. With the intake manifold removed I'm not sure that you have to rotate the valve for clearance but it should just come straight up and out. They get really corroded with gunk and may take a lady's foot crowbar to pry out. It's not easy sometimes, but only the two bolts hold it physically in.
Old Jun 21, 2010 | 10:58 PM
04scurs's Avatar
04scurs
Thanks NPCCPARTSMAN, it workded as you said.
Old Jun 21, 2010 | 11:06 PM
m-chan68's Avatar
m-chan68
The oil cooler bolts to the engine block are to be torqued to 16 ft-lbs. as per Ford Workshop Manual specs.
jlutes
Apr 29, 2009 11:00 AM
BigDa
1997 - 2003 F150
Oct 1, 2007 01:45 PM
corpsedub
24
Feb 1, 2005 05:19 PM
nhfire 77
May 7, 2004 07:08 PM
rich gill
18
Jan 19, 2004 10:19 PM
