Was wondering if you had a vac boost gauge and it read into the vac areawould that be helpful in determining you have a air leak. Just wondering since that wouldn't be a bad idea as I'm looking to install some gauges finally.
Not really but read on here that someone used it to determine they had a leak on the intake seal where the orange boots go into the intake. Just thought if there was a leak there it may read on the vacuum side due to loss of boost pressure reading from the map sensor line.
