> No, it's the drivers rear quarter window in an extended e 4wd.
Sorry, that was not very clear from your original post.
If you remove the old window, you will find that the factory used a butyl rubber sealant that can be softened when heated. There is an ideal temperature at which to work with the stuff; it will peel right off of the metal frame. You should get the same stuff to seal the new glass. The last time I did this I got the sealant in the form of a long rope from my local auto parts store. I stuck it into a groove around the frame, and pressed the glass against it. You insert the little studs on the glass into the holes around the frame and gently tighten the nuts on the other side to draw the glass into place. Turn every nut a little at a time until the frame around the glass fits flush against the body work.
You will have to remove most of the interior trim from behind the driver's seat and back in order to get to the inside of the window frame to first remove the old glass and then install the new.
ok. Thanks. I haven't really looked at the problem. Just vacumed up the mess and taped some plastic to it . Tried to ignore it i was so mad. I've had the 93 e 4wd drive for five years now and only just turned 86,000. Kinda attached to the old Green Bean.
OK. dirty deed is done. Received window from junk yard in Minn. shipped to wash. st. 70.00. Installed on saturday. Damn poly butyl tube was 22.00.Everything went well , fairly easy. Except the poly butyl in my hair.Thats some " stickey Shid.
Should have gotten the butyl rope sealer. Unless it's really hot out, you can work it with your bare hands and have almost none stuck on you. It as a backing tape that you press on against the body work, then you peel it off. It doesn't ooze or drip like the stuff that you squeeze out of the tubes, and keeps its consistency forever.
Before you button up the interior, you might want to run water along the edges of the window from the outside and make sure none gets through inside.
