gauge problems
Old Jun 17, 2010 | 12:23 PM
dm ford rebal's Avatar
dm ford rebal
gauge problems
im in need of help plz igot none of my gauge working
Old Jun 17, 2010 | 12:24 PM
dm ford rebal
my truck is a 92 4x4 351
dm ford rebal
o ya it only a f150
Old Jun 17, 2010 | 12:52 PM
Franklin2's Avatar
Franklin2
For the oil pressure gauge and the water temp gauge, find the sending units on the engine. One will have a red/white wire and the other will have a white/red wire. The oil pressure sending unit is usually down low near the oil filter on a 351w.
With the key in run, engine off, take the wire off the sending unit and ground it to the block. The gauge should swing full scale hot or cold, low or high pressure, depending on which sending unit wire you are grounding. Then take the wire off the block and let it hang in the air, and the gauge should swing the opposite direction. If this works, then the wiring and the gauge are good, and you have a bad sending unit.
Old Jun 19, 2010 | 02:34 PM
dmeyer 351 4x4 rebel's Avatar
gauge problems
none of my gauges are working on 92f150 4x4 351w
