99 Expedition running rough
Old Jun 19, 2010 | 11:50 AM
johnkirk's Avatar
johnkirk
So today I sprayed the throttle body of my 1999 Expedition with 205K miles with air intake cleaner as I usually do every couple of Months. I also sprayed some starting fluid in the the intake. I started the vehicle & it was a bit difficult to start *** is the case after spraying stuff into the intake, but after letting it run for a fee minutes, the idle was going up & down & the engine seems to be running on 7 cylinders. Is there a possibility that I fouled a plug? I had all of the coil packs replaced last year. Could one of the coil packs have gone bad? I double checked to make sure that all of the vacuum hoses were connected & they are.
Thanks in advance for any help!
Old Jun 19, 2010 | 02:17 PM
alloro's Avatar
alloro
Which engine?
If the idle is going up and down then maybe you either knocked off a vacuum hose when you were in there, or dislodged something with the cleaner that is now making the IAC valve act sticky. I'd start by checking the hoses, then taking off the IAC and giving it a good cleaning.
Old Jun 19, 2010 | 04:31 PM
johnkirk's Avatar
johnkirk
I've got the 5.4L V-8. I'll double check the vacuum hoses & the IAC, which I'm pretty sure I replaced a couple of years ago. I would be surprised if the spray jarred something loose because I spray my intake every coupe of Months & 2 years ago I removed & cleaned it. It sure sounds like its running on 7.
Old Jun 19, 2010 | 09:21 PM
bcompton35603's Avatar
bcompton35603
how long since you changed spark plugs? I replaced mine last night in a 98 expedition 4.6L. It had only been less than 2 years and maybe 30000 miles since they were last changed, made a tremendous difference in the way mine ran.
Old Jun 19, 2010 | 09:45 PM
fun_suv's Avatar
fun_suv
Rev the **** out of it.
Old Jun 20, 2010 | 12:45 AM
johnkirk's Avatar
johnkirk
How in the world do you get to the bottom bolt on the IAC? This thing is impossible to get off. I have taken the throttle body off before but I an trying to avoid doing so.
Any suggestions???
Old Jun 21, 2010 | 11:01 PM
johnkirk's Avatar
johnkirk
Ok. I found one of the boots on a vacuum hose near the back of the intake was bad so I replaced the entire PVC hose cluster. Also replaced the two O2 sensors & PVC valve. The truck still idles badly, like it is running on 7. Should I replace the IAC? Also, could the MAF be bad? I sprayed & cleaned it but it does have 203k miles on it. If the MAF is bad would the truck run rough?
Thanks,
Old Jun 22, 2010 | 09:01 AM
hotstang's Avatar
hotstang
Code, code?
Are there any codes with this?
Old Jun 22, 2010 | 10:20 AM
G Ford Fan's Avatar
G Ford Fan
Proccess of elimination my friend.
It was not running rough before you sprayed the TB. Re-trace all your steps and check everything you changed or removed to spray the TB.
I recently sprayed/cleaned the TB on my Expedition. However, I had my wife start the truck for me and I feathered the throttle to keep it running so I could spray/clean it while it was running. This helps remove/burn deposits all through the intake track. I had no problems with my rig after the spray-down. the inside of my TB was NASTY before I sprayed it, afterwards it was nice and CLEAN.
Good luck!
Old Jun 22, 2010 | 10:24 AM
alloro's Avatar
alloro
No, a bad IAC will give you a low or erratic (up & down) idle like you stated in your first post, but it won't give you a skipping feel. If you're confident the IAC is cleaned and working, I'd start looking for a skip next.
The easiest way to do this is to one at a time disconnect the 2-wire plug going to each COP. Once you disconnect one that doesn't affect how the engine idles, you've found the problematic cylinder.
Just so you know, each time you disconnect a COP, a code will be set and the CEL will turn on. Once you reconnect it and turn the key off/on the code should go away and the CEL go off.
kunard333
1983 - 2012 Ranger & B-Series
18
Aug 24, 2014 11:17 PM
Wayne Soini
May 1, 2012 12:11 PM
mniewald
Jul 26, 2011 04:46 PM
jsavlen
May 28, 2009 08:27 AM
Kijutsu
Aug 22, 2008 01:46 PM
