squeel from engine compartment when cold
Old Jan 18, 2002 | 10:25 PM
jrahn's Avatar
jrahn
Old Jan 21, 2002 | 10:17 AM
jetjock46's Avatar
jetjock46
I have the same problem with my 2000. I checked out the service bulletins and found there is one. It is number 14365. I don't know what it says, but it seems to apply to this case.
If anyone can get a copy of the bulletin that would be of great help.
Thanks
Old Mar 3, 2005 | 08:47 AM
Mark01835's Avatar
Mark01835
I have a 97 with the 5.4L, I have had the squeal sound for almost 2 years, It all started just before my power searing pump went, So I had the power steering pump replaced, It continued to squeal, so I have had the belt replaced, and the belt tensioner, I still have the squeal, So like once a month I put some belt spray on the belt, The squeal goes away,
Old Mar 3, 2005 | 05:56 PM
kb-65's Avatar
kb-65
I have a 99 with 100000 miles and no squeals or piston slap. just a small exhaust leak on the pass side for about 3 seconds then it goes away. I would remove the belt and inspect everything the belt goes around. If it all checks out ok Start it with the belt off and see if the noise is still there . You can run it for a few min. (5 min.) with the belt off.
Old Mar 5, 2005 | 05:09 PM
Trucker22's Avatar
Trucker22
Engine Squeal when cold
I have the same intermittent squeal on my 2000 Nav when it's cold--doesn't last long . Jetjock46---I can't find that TSB on AllData. Has anyone found the TSB 14365 that he refers to??? Any idea what it says??
Old Mar 6, 2005 | 11:30 AM
merczephyr's Avatar
merczephyr
Make : FORD Model : EXPEDITION Year : 1999
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Num : 14365 Date of Bulletin: SEP 01, 2000
NHTSA Item Number: 618636
Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE:BELTS AND ASSOCIATED PULLEYS
Summary:
THIS BULLETIN ADDRESSES CONCERNS A NOISE AT INTIAL ENGINE STARTUP WHEN COLD FROM THE ACCESSORY DRIVE BELT. *JB
That's all I've gotten so far. I can't find the full text of it for free, and don't have the cash to pull it up. Looks like a trip to the dealer is in order, to see if they can give me a print out of it.
nbtone
22
Jul 17, 2020 02:30 AM
Strydez
1997 - 2003 F150
Aug 6, 2015 01:29 PM
chadjeppig
20
Apr 1, 2014 11:42 PM
dyoungen
Mar 8, 2014 04:55 PM
4Ranger4
1983 - 2012 Ranger & B-Series
31
Sep 26, 2010 07:31 AM
