Slight missfire problem
Old Jun 18, 2010 | 01:08 PM
FxRiZBeAsTLy's Avatar
FxRiZBeAsTLy
Hi, I'm new to the forums.
Anyways, I have a 1979 F-150 with a 351w. It has a Mild cam, Headers, edelbrock 600cfm, Only mods i know of. Anyways, everysince I bought this truck about 4 months ago, its had a "slight" missfire to it especially when I hardly give it any throttle or Low rpm. I also Have to run about 1/4 choke for it to run smooth. I have replaced plugs, plug wires, distrubter cap and rotor, coil pack, inline fuel filter, and have used carb cleaner on my carb. Nothing really helped it at all.
Well, one day after I did all this, I decided that I would pull the distrubter and check and see if the gears were damaged. They all were ok. So I tried to get the distrubter back in where I took it out, and couldn't so I put it 1 tooth off, can't remember which way. And the missfire was completely gone, and I could run it with "No choke", instead of running with half.
It ran Good for about 2 weeks, then about a week ago, I decided to be a show off and do a burnout to show my dads dodge up :S . Long story short, it fell flat on its face, and now the slight missfire is back. And I have to run with 1/4 choke for it to run halfway smooth again.
I'm not sure what this could be, carb? Ignition problem? Any help will be appreciated.
Old Jun 18, 2010 | 05:53 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Is the distributor moving? What ignition timing are you running?
What are your idle misxture screws set to? 2 1/2 turns "out" is a good place to start and then fine tune with a vacuum gauge.
Josh
Old Jun 19, 2010 | 12:18 AM
FxRiZBeAsTLy
Well, I'm not sure what ignition timing i'm running. How do I check? And my idle mixture screws are set to 3 1/2.
Old Jun 19, 2010 | 11:27 AM
garycamburn's Avatar
garycamburn
Hello my name is Gary.
it seems like it has a timing problem cause you said when u removed the distributor on tooth and you said it ran good. so i would try the time and chain and gear cause it sounds like it wore, thats why it jumps and thats why it runs good and then it wont run good. and that might be the problem so check that!
thanks have a great day
Old Jun 19, 2010 | 09:07 PM
mitch1500's Avatar
mitch1500
check ur vaccuum advance, and it mite be gettin too much fuel i got a edelbrock set to about 2 3/4 turn,
