Sponsored by: Auxito
Squeaky steering
Old Jun 18, 2010 | 12:18 PM
'98F150's Avatar
'98F150
Squeaky steering
98 F150 4.6 4x4. When I turn my steering wheel to one side or the other it squeaks. The sound is coming from the engine side of the firewall and sounds like a rubber bushing or a joint. Is there a grease fitting or something on the steering column that should be lubricated on occassion?
Old Jun 20, 2010 | 12:17 AM
Torky2's Avatar
Torky2
'97's were known for the "lubricated for life" joint at the end of the Pitman Arm squeaking.
I bought a needle tip for my grease gun, and stabbed the rubber boot around the backside. Put enough grease into it to swell the joint's rubber boot some.
Figured that was a temporary fix, that it would return and I'd have to replace the Pitman Arm. Never squeaked again. It's been many years since I did that.
Don't know if 1998's were any different.
Old Jun 20, 2010 | 09:49 PM
'98F150's Avatar
'98F150
Thanks for the info Torky2. The whole front end needs greasing so I'll give it a try.
whitecougar
1997 - 2003 F150
Apr 17, 2007 09:16 PM
whitecougar
1997 - 2003 F150
Mar 13, 2007 08:37 PM
T-boneJax
1997 - 2003 F150
May 6, 2004 10:08 PM
nobullhere
1997 - 2003 F150
Feb 6, 2003 09:24 AM
