The seal disappeared in between the u-joint and axle shaft on the drivers side. NOT THE WHEEL. And I've been to Napa 4 times for the damn right seal and every damn name I've tried is wrong. Maybe they don't have it, but I need an inner axle shaft seal, I think. Someone help me out please. I need it ASAP. Just give me a name that I can use to get the right seal at AutoZone or Napa or I don't give a ***** where...
I got new seals for my 250. I went to Napa and got the seal and bearing kit. Part # bk6. This is the seal and bearing between the u-joint and wheel. This kit is for the ttb front end. I'm a bit confused as to what exactly what you are looking for. Hope this helps.
Presuming you're talking about the axleshaft seal for a Dana 60 front. I had mine done this winter, and my mechanic ran into the same problem... listed part from parts store didn't fit. He ended up reading the part number off one of the seals and getting that part, which was different than what the parts lists said.
While you have the differential apart, might as well replace both seals. I gather the only additional work for the second seal is pulling and replacing the seal itself, and you probably need to do that anyhow to get the part number.
