Ball Joint ? 2wd
Old Jun 18, 2010 | 08:46 AM
bkgeig's Avatar
bkgeig
Ball Joint ? 2wd
I had new ball joints pressed into the spindle of my 2wd and this morning bolted the spindle back on. With the ball joints torqued to spec, 99lbs lower and 60lbs upper, the spindle is noticeably difficult to turn. It takes considerable force for me to turn it by hand. Is this normal? I assume it is, and that my old ball joints were really loose, but I want to make sure before I bolt everything back up. Thanks.
Brian
Old Jun 18, 2010 | 10:52 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Did you grease them prior to installing them? It always makes installation easier before you grease them one last time...
Old Jun 18, 2010 | 10:59 AM
T8R's Avatar
T8R
Make sure they're greased. That aside, they should be a bit stiff for awhile when they're still new. They'll loosen up a bit after some driving. (Mine was the same way.)
Old Jun 18, 2010 | 11:57 AM
bkgeig's Avatar
bkgeig
Mine came with grease fittings. I shot some grease in them after they were installed. Sounds like I've done everything I correctly till now and shouldn't worry about the stiffness.
LOWFOMOCO
Jan 2, 2012 07:06 PM
manosdelfuego
Aug 27, 2010 10:44 AM
Skijeremy
1997 - 2003 F150
Jun 30, 2008 06:59 PM
agillings
Oct 26, 2000 12:40 PM
