need help on getting tail lights to work
Old Jun 18, 2010 | 07:51 AM
lukes73's Avatar
lukes73
So I just bought a 73 f100 and the brake lights don't work and the taillights don't either but the signal lights work....brand news bulbs and the fuses r okay.....any suggestions guys?
Old Jun 18, 2010 | 08:26 AM
Joseph69's Avatar
Joseph69
Common problem, check the socket, there is a tab near the glass part of the bulb for the ground, that rusts away. Test it by putting in a ground wire jumper touching the bulb, then by a new socket(s).
Old Jun 18, 2010 | 08:28 AM
704 dentside man's Avatar
704 dentside man
By tailights not working, do you mean brake lights, or when you turn the headlights on, you still don't have anything? If it's just brake lights, I'd suggest a new brake switch. If it's the latter, Bad sockets, grounds, plugs...check them, clean them, replace them if need be.
Old Jun 18, 2010 | 10:50 AM
MrHomz's Avatar
MrHomz
Check your signal switch in the steering column. Mine's acting up itself....when I step on the brake, only my right brake light comes on. If I hold the turn signal lever up just a little to the right, the left brake light comes on and the right goes out. Sometimes neither of them work, sometimes they both do. My problem is in the signal switch, it can cause the brake/tail lights not to work. (Mine is broken, I can hear a little piece rattling around in there...lol)
