04 ford multiple codes
Old Jun 18, 2010 | 05:24 AM
bwitty's Avatar
bwitty
I have multiple readings p0320, p2106, p0446. I've read several posts on each of these codes, they seem to be completely different issues, I'm wondering if anyone can clue me in on whether or not my assumptions are correct or if this is all pointing to one problem.
Old Jun 18, 2010 | 06:44 AM
shorod's Avatar
shorod
P0320 - Ignition Engine Speed Input Circuit Malfunction
P0446 - Evaporative Emission Control System Vent Control Circuit Malfunction
P2106 - Electronic Throttle Control (ETC) Throttle Position (TP) Sensor, Throttle Control Motor
From what I've read, the P0320 could effect the P2106, so you should remedy the P0320 first. For the P0446 I'd start by making sure the fuel cap is on correctly and securely.
-Rod
Old Jun 18, 2010 | 06:48 AM
ncranchero's Avatar
ncranchero
Hard for me to see a connection, from what I know. Have you reset the PCM to see if the same codes return?
Are you using a moderate/high power radio transmitter in the vehicle?
Old Jun 18, 2010 | 10:57 AM
aquanaut20's Avatar
aquanaut20
I had random Ghost codes for a while, tracked it down to the harness connector on the driver side of engine, opened connector sprayed with WD40 and no codes for 2yrs...
05FordTough
2004 - 2008 F150
Nov 17, 2014 08:23 AM
Boss9F100
Aug 31, 2014 01:26 AM
makuloco2000
Escape & Escape Hybrid
Aug 25, 2014 12:23 PM
dockrocker
Modular V8 (4.6L, 5.4L)
Feb 26, 2014 11:53 AM
creolex
Sep 8, 2006 09:33 AM
