5.4 triton multi codes
Old Nov 16, 2014 | 09:44 PM
05FordTough's Avatar
05FordTough
I am a new user to this forum,I have a 2005 F-150 W/ 5.4 triton, and am having multiple codes. They are: p0172- System to rich(Bank 1), p0174- System to lean(Bank 2), p0300- Random misfire, p0303- Cylinder # 3 misfire detected, p0304- Cylinder #4 msfire detected. Could anyone Please hlp me!!!!
Thank you 05 FordTough
Old Nov 16, 2014 | 09:57 PM
96_F250_Deezal's Avatar
96_F250_Deezal
Clear the codes and replace the spark plugs and coil boots.
Old Nov 17, 2014 | 08:23 AM
70f100longbed's Avatar
70f100longbed
You also need to check for leaking injectors on cyls 3 & 4. You prob will need a new cat converter if the injectors are leaking. Pull the fuel rails out if the intake and cycle the key to run a few times. There should be no fuel leaking from the injectors.
Unluckiest
2004 - 2008 F150
Mar 28, 2017 03:57 AM
16chartr
2009 - 2014 F150
Sep 6, 2016 08:01 PM
TransplantX
Modular V8 (4.6L, 5.4L)
Sep 19, 2015 10:08 AM
Roddy's Dad
Jan 9, 2015 07:37 AM
acschex
Apr 3, 2013 06:26 PM
