6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Low coolant
Old Jun 21, 2010 | 09:10 PM
Industrial_dude's Avatar
Industrial_dude
well I took posession of the truck on thursday last week. Drove it so far 100 miles I knew it was low at first but I didnt think it was really really low until the clutch fan stayed on non stop for maybe 50 miles on my way home from Disneyland and the needle went past half way a couple times then I just put it in cruise control at 65mph. Got home around midnight parked it and went to Napa the next morning and bought a gallon of gold coolant, I didnt even see a sign of coolant, today on my way to work I stop and buy another gallon I put it in and still no sign. when I get to work I dumped a gallon of distilled water and finally got it to the cold line mark. Went to the bank got acheese burger came back to the office and took the pics I just posted and yes the coolant level dropped down to where its almost not even visible, I think we all know why based on that pic I posted....
Old Jun 21, 2010 | 09:11 PM
Industrial_dude
Originally Posted by kane gray
Is your truck a Job 1,2, or 3?
it says 06/07 behind the door what "job" does that make it?
Old Jun 21, 2010 | 09:29 PM
kane gray's Avatar
kane gray
That is the very early start of job 2.
Old Jun 21, 2010 | 09:32 PM
Industrial_dude
Originally Posted by senix
Take it back and get the radiator fixed. Ensure that the ventri recall was completed on the truck.
Recalls can be checked using your vin.Recall Information - Ford
It is time for a coolant flush so that might as well be done, use the Ford or Napa Gold coolant, ensure it is the right spec according to ford.
It is typical for a small leak at the seams on these trucks, but a hiss sounds like a puncture in the radiator.
It says there are currently no recalls on this VIN
Old Jun 21, 2010 | 09:33 PM
Industrial_dude
Hhmm thank you thats good to know. Is there any problems related to this build?
Old Jun 22, 2010 | 04:12 AM
capt caper's Avatar
capt caper
there is tsb's out on the venturi valve and for hyper thermostats. Both can cause the radiator to go. I had 2 replaced because of these. So just replaceing the raditator may not solve the problem
Old Jun 22, 2010 | 05:18 PM
Industrial_dude
that is what the Tech said today, He said when the thermostat fails it creates air pockets and creates cavitations in the water pump housing also. He showed me an old housing with the cavitations from another 6.4 . Sounds like they know whats going on.
I got to test drive the 2011 6.7 diesel, for the price tag I dont know... the only difference I felt right off the back was a nice punch in acceleration out of the hole once on the freeway it wasnt much different. What I really LOVED was the seat coolers man were those comfy. My A$% felt nice and cold.
Old Jun 28, 2010 | 05:29 PM
Industrial_dude
got it back today. Had a new radiator,thermostats, and water pump front cover installed under warranty and now I have a 12month/12,000mile warranty on the repairs. Hauled A## on the way home to see if it would leak, coolant stayed right at the cold mark line so far.
Old Jun 29, 2010 | 06:35 AM
ruschejj's Avatar
ruschejj
Glad it's fixed with no damage to the engine.
FYI: Many of us have had 2,3 or even 4 radiators. After about 35K miles you'll know, that seems to be my pattern.
Love your boat, MX rig, and that Ex. Wow, what a sweet Ex!
Old Jun 29, 2010 | 06:44 AM
capt caper's Avatar
capt caper
You should be good to go now. I've been fine. I hope they didn't charge you a $100 deductable. Mine did this past spring. I called Ford and they said no deductable. He then called my dealer and I got a check coming back.
Old Jun 29, 2010 | 06:47 AM
senix's Avatar
senix
Ensure you check it cold at least weekly, make sure it always stays above that lower hose so no air gets in there.
Old Jun 29, 2010 | 06:25 PM
Industrial_dude
Ruschejj- Thanks for the compliment I miss my Excursion everyday but it was time for me to move on. A radiator every 35k isnt very comforting lol.
Capt-Caper- No I didnt pay them any deductable and they even gave me a rental which was great.
Senix- Thanks for the tip and contribution to my thread. Checking the coolant level on my vehicles has become pretty much a Habbit for me now after the 6.0 lol
First Tow for me tonight with my Car hauler and then taking the boat out this weekend to Long beach harbor to see the Queen Mary Firework show from the water. Possibly even go to Catalina island for Lunch and a drink depending on the weather .
HAVE A HAPPY 4TH OF JULY EVERYONE!
Old Dec 12, 2010 | 07:14 PM
  #28
bhd's Avatar
bhd
What's the procedure if it does get that low? Mine is almost empty.... Need to top it off. Found the leak too.
Old Dec 12, 2010 | 07:21 PM
  #29
senix's Avatar
senix
I would not drive it low. Sucking air will cause caviatation and then that will be worse.
Fill the degas bottle to the max line. It is going to go down because of the leak.
what leak do you have?
Napa sells the same spec of coolant that ford requires.
Pikachu
Dec 26, 2016 08:26 AM
03diesel
Nov 10, 2016 06:56 PM
Mr_CarMan007
Jan 24, 2016 08:06 PM
Mr_CarMan007
Jan 6, 2016 01:48 AM
Race8100
Jun 13, 2014 10:28 PM
