Tubular side steps
Old Feb 6, 2003 | 11:37 AM
CSF250's Avatar
CSF250
Tubular side steps
Is there any company that makes tubular side steps for a 1979 F250? I have searched every catalog out ther and they only seem available for later years?
Old Feb 6, 2003 | 11:51 AM
79f3504x4's Avatar
79f3504x4
Tubular side steps
I need some also,all I can find are 80-up. Not sure if there is a frame difference.
Old Feb 6, 2003 | 10:46 PM
Boss_358's Avatar
Boss_358
Tubular side steps
The frames on the pre-80's trucks are significantly narrower than the later models. The best bet for the older trucks is going to be make the ones for the newer models fit somehow. Or fab up your own. I know a guy who has Expedition side steps on his crew cab Chuvy. So anything is possible with an imagination.
Old Feb 7, 2003 | 08:35 AM
Purely Ford's Avatar
Purely Ford
Tubular side steps
I have installed rear bumpers and brackets from a 1988 F150 onto a 1976 F100 and the frames are the same width as far as I could tell. That doesn't mean the frames are dimensionally the same so that brackets for accessories will work. I am pretty sure there are different curves in the frames from the 1970s to 1980s.
The real difference you will run into is the way the 1970s and 1980s body/cab sits on the frames. This will cause clearance problems when using psarts made for one used on the other.
Even with these problems that may occur it is worth checking out especially if you can make your own brackets to overcome them.
Let us know if this works out because I have considered using something like this as well.
Old Feb 7, 2003 | 04:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
Tubular side steps
You may want to search the Aftermarket & Appearance forums also.
snowdog79
Jun 15, 2013 02:34 PM
unyalli
Oct 18, 2012 06:23 AM
ATX F250
6.4L Power Stroke Diesel
Apr 20, 2012 03:34 PM
garyrox5
2009 - 2014 F150
Dec 31, 2011 07:57 PM
Johns331
1997 - 2003 F150
Apr 27, 2000 07:43 PM
