clutch?
Old Jun 17, 2010 | 10:59 PM
hedhntr's Avatar
hedhntr
clutch?
my 97 hops pretty good in reverse especially backing a trailer, no issue in any of the forward gears i do have a oil leak that i cant find its not on top its either a plug on the upper passenger side or rear main that could be dripping on the clutch, maybe a throw out bearing any ideas could it be the clutch starting to go out. the dual mass flywheel came apart and I replaced it with a single about 30000 mi ago. Thanks
Old Jun 17, 2010 | 11:03 PM
chicagodragon's Avatar
chicagodragon
in one direction and not the other sounds like an engine mount. check the one on the pass side. just a thought
Old Jun 18, 2010 | 02:15 PM
hedhntr's Avatar
hedhntr
i will check when i get home thanks
Old Jun 18, 2010 | 03:32 PM
strokin'_tatsch's Avatar
strokin'_tatsch
sounds like hot spots to me... you slip that clutch frequently when backing trailers and stuff?
Old Jun 18, 2010 | 06:56 PM
FARM69's Avatar
FARM69
Possibly a warped clutch disc?
Does it have an aftermarket clutch?
Old Jun 18, 2010 | 11:57 PM
hedhntr's Avatar
hedhntr
I try not to slip it at all but it happens, I replaced the dual mass flywheel with a single and put a clutch in about 30000mi ago. this was before i was on this site and didnt pay any attention to what clutch, it all came in a kit.
Old Jun 19, 2010 | 07:27 AM
Talyn's Avatar
Talyn
Hot spot from oil
or engine mount
since its only doing it in reverse, it sounds more like a bad mount.
