MAF and roller conversion 85 f150
Old Jun 17, 2010 | 03:17 PM
JB_85F150's Avatar
JB_85F150
I've been kicking around the idea to do a Mass Air Flow and roller conversion to my 85F150. I see so many great cams out there but say they cant run with the speed density or whatever, says most of them need to be on a MAF setup.
I've read several MAF converisions online, has anyone on here done this?? Do you like it?
Just curious, I've been kicking around the idea of possibly a MAF conversion and a Roller cam conversion.
Thanks,
Josh
Old Jun 17, 2010 | 03:59 PM
Kemicalburns's Avatar
Kemicalburns
Ford Fuel Injection has lots of stuff on the subject.
for your setup going with a mustang efi mass air harness should do the trick. you could also run a mustang a9l or a9p ecu to control it.
just understand cams that work well in cars dont work well in a heavy truck. also a cam is rather pointless unless you have the exhaust redone, heads either worked over or aftermarket.
tell us a bit about your F150, what tires its running and such and how you use it. all this motor work might be for not.
Old Jun 17, 2010 | 07:16 PM
JB_85F150's Avatar
JB_85F150
Well, In all honesty, after thinking about it for a while I probably wont do this until I build a new engine for the truck. Right now its pretty much stock with a rebuild a few years ago. I plan on finishing the restoration on the truck then work on building a semi hot motor to drop in it.
I'm going the route of a sport truck for the restoration, dropping it 3" with a DJM setup. It currently has 17" crager style wheels (I cant remember the tire size at the moment, I'll look at them in a bit)
I figured during the motor build, It will be easier to get everything converted then or just order a crate motor, but it just seems to be cheaper to get a short block (they are pretty cheap from what i've seen) and build it the way I want it. Like I said though, nothing too crazy, but have it talking a little smack with a little cam .
What a good set of heads and mating headers I could use on the truck withough having fitment issues when installing the headers? I go the route of shorties?? What kind of cams do you recommend for a truck? oh yeah the truck is an automatic as well.
Thanks for the help guys.
nighthawk285
24
Jan 9, 2017 01:07 PM
Timdnj
Engine Swaps
Feb 19, 2016 10:45 AM
Gasquatch
Arizona Chapter
Sep 27, 2015 07:32 PM
HAVEaSigAR
33
Jul 31, 2014 04:39 PM
ManhattonNite
Jun 11, 2004 08:36 PM
