CPS failure?
Old Jun 17, 2010 | 02:18 PM
Fluke01's Avatar
Fluke01
CPS failure?
I was driving my F250 Harley (Turbo) on the highway and it just outright died. Fuel pump is good and just changed the filters. So i was under the impression the next thing would be the CPS. I read that it could be the power chip but I dont know where that would be. Any thoughts?
Old Jun 17, 2010 | 02:30 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Open the secondary fuel filter cap to INSURE there is fuel in there. Beyond that, you gotta wait for the experts to get home from work!!
BTW, let us know model year of vehicle. I assume it IS a 6.0?
Old Jun 17, 2010 | 03:57 PM
Fluke01's Avatar
Fluke01
thanks. yes i did that. i posted once already because i thought it was the fuel pump. Its an 05 F250 6.0 Harley Davidson turbo diesel
Old Jun 17, 2010 | 07:20 PM
cheezit's Avatar
cheezit
you need to know what the icp pressure is. check the tech folder on how to do this. check for stored codes.
there are a few things that can cause this. check fise f2-22, check wiring to fan clutch, check fuel pressure.
if you have nothing to go off at that point you can remove and inspect the ipr valve.
also will the truck start when its cold?
Old Jun 17, 2010 | 07:30 PM
Fluke01's Avatar
Fluke01
no starts. no codes came up when we put it on the computer. the truck just died. completely. no check engine light. the only thing i have read that resembles the issue i am having is the CPS sensor. i actually went and bought one but i cannot see/access it.
Put it this way...this is my first diesel and i am not good at trouble shooting. i can replace parts, but i dont know what icp pressure is or how to check fuel pressure. i also dont know what an ipr valve is, but i will google it. i didnt know what the CPS was until i read about it today.
Old Jun 17, 2010 | 07:34 PM
cheezit's Avatar
cheezit
the cps on a 6.0l going out is very rare. more failed harness then cps sensors. that was an issue with a 7.3
the cps is located behind the powersteering pump and can be accesed from the bottom.
no need to use google. this site has a great tech folder. use it its your friend.
If you need more info/help just ask.
Old Jun 17, 2010 | 07:46 PM
Fluke01's Avatar
Fluke01
yea, thats all above my pay grade. i gotta take the top fuel filter assembly off to access the ipr valve in the V of the engine? and my take on it is that i would need an independent icp pressure gage for diagnosis. they warned me to go ahead and take it to the shop...but still i refuse!
Thanks for the advice
Old Jun 17, 2010 | 07:50 PM
cheezit's Avatar
cheezit
once again if you read the tech folder you would see it can be done by measure voltage at the icp sensor. if you have more then .8v cranking then its good.
you dont remove the filter housing to remove the ipr. once again you are looking at info for a 7.3. you have a 6.0. the ipr is behind the turbo on the high pressure oil pump.... tech folder for that info as well
not tring to sound or be rude just tring to point you in the right place for the correct education you seek. there are a number of people here with a lot of knowldge but you will have to do some work to learn it.
I for one am glad to help you.
were about in tx are you?
Old Jun 17, 2010 | 08:05 PM
Fluke01's Avatar
Fluke01
Im in San Antonio. New to the forum. Not rude, its fine...i see the tech folder info...still learning my way around here. Its all good and organized, but im not much of an "enthusiast" until something goes wrong. other than that i just drive around and look "down" on every one else on the road on my way to go kayaking or camping or hunting...or work i suppose
i was just telling my daughter that i am Civil...not Mechanical. ill do some homework tonight and get back at it again tomorrow. Thanks again.
Old Jun 17, 2010 | 08:13 PM
cheezit's Avatar
cheezit
im an enthusiast by force only. welcome to fte.
sorry to say but san antonio is a ways away.
also there is a tx chapter here too.
Old Jun 17, 2010 | 08:34 PM
Fluke01's Avatar
Fluke01
I saw that. When i fix my truck Ill browse a little more and look at the Texas chapter.
The icp sensor seems to be a problem with the 03/04s. I heard when i was looking for a truck not to get an 03/04. It also seems like a bad icp sensor would show a code.
Old Jun 17, 2010 | 08:42 PM
cheezit's Avatar
cheezit
some will some wont. you are correct on 03/04 had lots of icp concerns
Old Jun 17, 2010 | 10:17 PM
Fluke01's Avatar
Fluke01
after reading through all the suggestions, it seems the most likely culprit is the ipr valve and/or the HPOP thing. now here is where i give permission to call me an idiot, but i read that is located behind the turbo, but i dont know where that is or what it looks like. when i was under the truck i didnt see a sign that said "turbo". But seriously, if i pulled the thing out, how would i know if it was good or bad?
Old Jun 17, 2010 | 10:21 PM
cheezit's Avatar
cheezit
the turbo is the big thing in the center of the engine. If the ipr screen has a hole in it or it is sucked in or there is a blockage in front of the screen then its bad. other then that it would take a little bit of diag skills.
Old Jun 17, 2010 | 10:27 PM
npccpartsman's Avatar
npccpartsman
Put this link in your favorites: Powerstroke 6.0L Technical Intro Manual and add this one to it: 2005 6.0L Bible Update Table of Contents
These two will give you a really good idea where the basic components are located and the second one gives you a list of trouble codes. Get yourself a Scan Gage II to read codes with. It can save you a TON of cash at the dealership (with a little help from your FTE brothers.)
