Polarizing Generator
Old Jun 17, 2010 | 12:53 PM
Steves55's Avatar
Steves55
This may be a dumb question......when I was connecting my in-line fuse wire for my heater switch, I only disconnected the negative cable from my battery (6 volt-positive ground). Upon reconnecting, do I need to polarize my generator?
Old Jun 17, 2010 | 02:16 PM
BlueOvalRage's Avatar
BlueOvalRage
Probably not. The field coils in the genny will normally retain their polarity when the system is disconnected for a short time.
Old Jun 17, 2010 | 07:59 PM
Julies Cool F1's Avatar
Julies Cool F1
The only time you need to polarize is if you replace the generator. As BOR noted this procedure is to install a magnetic charge in the generator filed coils and once it is done it's perminent (baring a rebuild, demagnetizing or alien abduction).
Most regulators tell you to do it when you install a new regulator and that's fine - it won't hurt anything to do it again.
F250Rob
Jan 18, 2017 11:21 AM
Cougar54
Sep 20, 2015 09:30 PM
jimstrecker
Feb 13, 2011 01:33 PM
robe
Mar 8, 2010 07:52 PM
1950ford
Sep 28, 2007 01:00 AM
