spark plug wires
Old Jun 17, 2010 | 10:13 AM
backdraft341's Avatar
backdraft341
spark plug wires
i have a 1986 f-150 supercab with a 302 fuel injected, 2 wheel drive, auto. is there a way to check spark plug wires to see if there good? can you use a voltmeter? i dont want to buy a new set if i dont have to? thanks for any ideas.
Old Jun 17, 2010 | 10:58 AM
Grubbworm's Avatar
Grubbworm
You can ohm them out with a voltmeter, just make sure that you take into account the length of each wire. They should all be relatively close.
Old Jun 17, 2010 | 12:45 PM
Rockstone's Avatar
Rockstone
Check with an ohmmeter. There should be appx. 5000 ohms of resistance per foot of wire. If it is much more, replace it.
Old Jun 17, 2010 | 01:52 PM
Grubbworm's Avatar
Grubbworm
My Bad. My voltmeter or rather my multimeter has an ohm setting.
Old Jun 17, 2010 | 06:07 PM
bashby's Avatar
bashby
BAd wires usually cause a missfire under load, if its not missing they're probably ok. Spraying them with a little water to see if it starts missing is a good check too
Old Jun 17, 2010 | 08:14 PM
backdraft341
how do i check them with a ohm meter? i have one but not very good with electrical.
Old Jun 17, 2010 | 09:18 PM
Rockstone's Avatar
Rockstone
Just stick one probe into each end of the plug wire and record your resistance. Best to do one at a time so it doesn't get mixed up.
asmolins
1983 - 2012 Ranger & B-Series
Sep 6, 2011 03:32 PM
76blue
Oct 26, 2009 11:48 AM
Marco1316
2004 - 2008 F150
Dec 22, 2008 08:11 AM
maddmaxx
4 Cylinder Engines
Jan 28, 2004 07:52 PM
hwimmer
Aug 9, 2003 07:15 AM
