towing capacity
Old Jun 16, 2010 | 09:18 PM
mikebrawn1's Avatar
mikebrawn1
towing capacity
Hey guys I know this question gets asked alot but i'm feeling kinda lazy so here goes. Does anybody know what the towing capacity is for a 96 f-150 with e40d and 3.55s? The sticker on the door is too faded to read. I guess the closest I can get is the rating for a super cab. I'm sure the crew cab conversion lowered towing capacity some. Thanks
Old Jun 17, 2010 | 04:55 AM
TexasGuy001's Avatar
TexasGuy001
I forgot what engine your truck has. Is it a 5.0 or 5.8?
Old Jun 18, 2010 | 11:26 PM
mikebrawn1's Avatar
mikebrawn1
Sorry, forgot to mention that. It has the 351 in it. Does the engine in the half ton make that much of a difference? I guess the torque difference would help it out some. Thanks.
Old Jun 19, 2010 | 08:58 AM
Conanski's Avatar
Conanski
Max combined weight is 11,500lbs for that powertrain combo in an F150 so weigh your truck and then you'll know how much trailer you can tow.
I'll add that the truck will need an additional trans oil cooler and a valvebody shift kit(not a plug-in electrical module) if you would like to keep the transmission under the truck and functioning normally.
Old Jun 19, 2010 | 09:03 AM
andym's Avatar
andym
You won't find your configuration in a Ford manual because your truck is an aftermarket conversion. Nice truck though.
Do you have something specific in mind to tow?
Old Jun 19, 2010 | 10:40 AM
mikebrawn1's Avatar
mikebrawn1
Nothing really specific to pull. Just gathering info for when I do. I have always been one to push the limits a little but won't do anything unsafe.
Old Jun 19, 2010 | 11:11 AM
andym's Avatar
andym
Stock, probably 6000 or so. With some upgrades, especially to the tranny, a good brake controller and an anti-sway hitch you might get away with 8000. But it's going to struggle up hills with that much weight.
eseec
59
Jul 25, 2012 09:55 AM
bcms6
All Things Towing
Dec 13, 2011 07:07 PM
Robertcoupe
Apr 17, 2011 08:53 PM
photomac
Jan 28, 2005 11:08 PM
trcklvngrl
Apr 30, 2001 07:58 PM
