What noises to expect when initial KOEO
Old Jun 16, 2010 | 11:21 AM
4ord06's Avatar
4ord06
When I do the KOEO and wait for the glow plug light to go off, I hear nothing except maybe the vac pump on the passanger wheel well sputtering, then stop, then sputter some more.
I do not hear my injectors (buzzing) or fuel pump operating. The thing is, my trucks starts fine every time and holds its own when I'm flooring for a 0-90MPH run. So the pumps gotta be working right.
Could the fact that its been 85F in the morning here be a factor?
I dunno.
Old Jun 16, 2010 | 05:53 PM
bpounds's Avatar
bpounds
You should only hear two things. The vacuum pump, and the fuel pump. The injector buzz was on shutdown, not startup. Not too many still have that flash anyway.
My vacuum pump is the loudest, and usually runs for 30 seconds to a minute. That's if it has had time to bleed down since the last run.
My fuel pump I cannot hear unless I kneel down on the ground next to the truck. When I change my fuel filters, I let it prime as long as it will run, 3 times minimum, before I try to start. It usually runs 20-30 seconds. I have to do this kneeling beside the truck listening carefully. While I'm down on one knee I usually say a little prayer that she will start. I mean, why not, I'm down there already anyway.
Those 2 are the only sounds I hear.
Old Jun 16, 2010 | 06:03 PM
npccpartsman's Avatar
npccpartsman
I thought the injectors were supposed to go through a self test on start up but I could be wrong. Other than that, fuel pump (stock pump is VERY quiet) and vacuum pump are it.
Old Jun 16, 2010 | 06:09 PM
bpounds's Avatar
bpounds
Could be. But without oil or fuel pressure about all they could do is check continuity through the coils. That might click I suppose.
I was thinking of the longer noises. There are a bunch of relays clicking as well as a whole lot of beeping going on. Does the glow plug relay click, or is it solid state?
william_04_x's Avatar
william_04_x
I have an old flash and my injectors tick for few seconds before I start the truck..
Old Jun 16, 2010 | 06:11 PM
bpounds's Avatar
bpounds
My hearing is pretty poor, maybe even worse than I thought.
But I can sure hear that danged vacuum pump.
MonsterLugz
Apr 15, 2018 12:48 PM
Evan_P
Jun 30, 2013 10:01 PM
Hiflyer746
Feb 8, 2009 11:03 PM
master link
Aug 24, 2006 11:19 AM
irishguyincc
1983 - 2012 Ranger & B-Series
30
Jun 20, 2005 08:13 PM
