Thinking about Magnaflow 16615
Old 06-16-2010, 08:24 AM
nnero's Avatar
nnero
nnero is offline
I am thinking about getting this exhaust:
http://www.magnaflow.com/02product/s...ne=all&id=4306
I would like the truck to have a nice rumble while idling and when under acceleration. I still want it fairly quiet on the highway (Its really nice on longer trips). Does Magnaflow have issues with resonance in the cab? Summit seems to have a good price. On the dyno chart, Magnaflow stated a 17hp increase. That seems pretty significant. Just wondering if I would notice a difference. Thanks.
Old 06-17-2010, 06:46 PM
danorules's Avatar
danorules
danorules is offline
Old 06-17-2010, 07:55 PM
lmahle's Avatar
lmahle
lmahle is offline
I have this system on my 04 Lariat 5.4 and it sounds awesome and does not have the drone at highway speeds. You will love it.
Old 06-17-2010, 08:00 PM
nnero's Avatar
nnero
nnero is offline
Thanks for the info dano, I will check that thread out. Hey lmahle, you would happen to have any pictures of that system on your truck would you? I would to see how it looks and see the clearance around the spare tires. Thanks.
Old 06-17-2010, 10:12 PM
Gearbanger 101's Avatar
Gearbanger 101
Gearbanger 101 is offline
Originally Posted by danorules
I was just going to point him in that direction.
FWIW....after having the system on my truck for over a month and a half now, with the muffler now broken in nicely, I still really like it.
A pick of my truck with the system on. Sorry for the low light level. Kind of a last minute shoot as I was running out of daylight....
...and a size comparison beteen the stock system and the Magnaflow...
Old 06-18-2010, 08:11 AM
nnero's Avatar
nnero
nnero is offline
Thank you for the helpful thread and pics. I actually posted the wrong link. I was talking about the split rear exit like this:
Magnaflow Stainless Cat-Back 2005-2007 16615 | Exhaust Systems | 04-08 F150 | Ford | Gas Power | Performance Truck Products
Im excited and just have to wait a month or so (I'm cheap). Oh, how hard is it getting the stock components off? There is nothing wrong with them and I would like to keep them intact.
Old 06-18-2010, 10:45 AM
Gearbanger 101
Check out the link danorules posted. I explained the removal of the stock exhaust in detail.
Start with the after cat pipe and loosen both ends to give you the most rotational leeway. After that, just do as stated...don't waste your time trying to wiggle the hangers out of the rubber isolators. Just unbolt the hangers themselves and remove the whole thing. There is no reason anyone needs to ruin a stock exhaust system by chopping it up.
Have a can of penatrating oil on hand and give the old bolts a liberal coating before starting.
...also back the rear end of the truck up onto a curb to give you another 6"-8" of height to work with. Every bit helps, but you still have to have weight on the suspension to make it work. Also, make sure the exhaust is stone cold before fiddling around with any of the bolts. It'll prove less "fussy" that way...not to mention easier to handle with your bare hands.
Old 06-18-2010, 11:17 AM
pb34's Avatar
pb34
pb34 is offline
I have basically the same exhaust. I have the 16614 which they don't make anymore I think they just changed the number to the 16615. Here are some pics of mine:
Old 07-14-2010, 12:12 PM
nnero's Avatar
nnero
nnero is offline
Thanks for all the great info and pictures. While looking for exhaust I was dissapointed that Magnaflow didnt have split-side rear exit exhaust, which is what I was originally looking for. While looking at Performance Truck Products I found this: MBRP 2.5" Cat Back DUALS (T304) EC/CC-SB 04-08 F150 4.6/5.4L (Split Side) S5204304 | Exhaust Systems | 04-08 F150 | Ford | Gas Power | Performance Truck Products
That is exactly what I want. Does anyone have experience with this brand. I remember seeing a members truck with MBRP exhaust, dano, it must have been you. I just noticed your signature. Thanks.
Old 07-15-2010, 08:26 AM
benningstspeed1.0's Avatar
benningstspeed1.0
benningstspeed1.0 is offline
mbrp has a split side exit. i had that system on my 07 f150 and liked it a lot. i have installed both systems and like the mbrp better. i have magnaflow on my navigator now and had to do some work to make it fit right and the same with my inlaws truck. the mbrp bolted up perfectly.
Old 07-17-2010, 01:01 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
IMO, if you want rumble, hang a Flowmaster under it. I have the Mag on my '05 and it is perfect for me. Cant hear it idle, but when you hit the gas it makes some noise. I have the SIDO, so duals out the back. Cant hear the truck on the highway. But now my '72 warmed up a little bit 390 will roar with the dual Flows. The Magnaflow to me is a more refined exhaust noise, whereas the Flow is just outright loud. If you want a lot of "deep rumble", dont use too much pipe after the muff.
Old 07-18-2010, 04:43 PM
lariat97's Avatar
lariat97
lariat97 is offline
If you want noise buy Flowmaster. If you want flow with good sound buy Magnaflow. I put Flowmasters on my F150 first. I hated them on long trips due to the drone. I put a dido Magnaflow with a x pipe built in it on last. It sounded good when you got down on it & didn't drone at highway speed. I had headers,true duals & the rear cats gutted on my 5.4.
Old 07-19-2010, 09:01 AM
gccch's Avatar
gccch
gccch is offline
I'm thinking about an exhaust upgrade now also, but this one only ports out to one side, right? Is there a set up that brings one pipe out to each side? Do I need to go with headers for that, and if so what else is involved? Can I still have a good quiet highway ride? Do I need a new program?
Old 07-19-2010, 09:11 AM
gccch's Avatar
gccch
gccch is offline
Just noticed this post... How does this system sound on the highway? Anyone ever compared this to the Magnaflow?
Old 07-19-2010, 12:47 PM
Coskid's Avatar
Coskid
Coskid is offline
To answer your first question I think you can get the configuration in several ways to have it port out the back or the sides just like the magnaflow. As for the sound on the highway I have no idea.
Quick Reply: Thinking about Magnaflow 16615
