Toploader clone
Old Feb 12, 2015 | 02:03 PM
circlecityrabbit's Avatar
circlecityrabbit
Toploader clone
New to the forum so Hi from Florida everybody!
I have a '76 F-100 custom, 360, 5.9L 3 speed floor shift. I recently figured out that I have the toploader 3 speed clone, the infamous "Orion" stamped transmission. So I have 2 questions, is this transmission even worth trying to rebuild or would I be better off just finding a true toploader from the boneyard and rebuilding it? and secondly, where can I find the info as far as what spline this transmission is so that I can find a true toploader with the right spline shafts? Any info anyone can provide would be greatly appreciated, thanks guys!
The stamps on the trans are as follows if it helps,
Case casting: "Orion" C-2603000
Case tag: RAB-J2
Tailhouse casting: RF-C5AR-7A040-B
Old Feb 13, 2015 | 05:02 PM
circlecityrabbit
No opinions at all guys? lol
Old Feb 14, 2015 | 08:18 PM
rockittsled's Avatar
rockittsled
Have not seen one or know anything about them but thought I would bump it
Old Feb 15, 2015 | 05:36 AM
gatorfor88's Avatar
gatorfor88
Maybe ND or Mike will chime in and help you out.
Old Feb 15, 2015 | 07:23 AM
5851a's Avatar
5851a
Check David Kee Transmissions, He has the charts and tells about the Orion but it sounds like it was a 4 speed od.
Old Feb 16, 2015 | 10:28 AM
Alexz265's Avatar
Alexz265
Rebuild parts are tough to get cheaply for it. Very hard to find in a yard. The input shaft should be 10 spline 1-1/16". If damaged/worn you would be better off with am upgrade to a more durable 4 speed (t-18,t-19, np435. Or if stock engine, you could use an SROD trans for overdive. Dimensionally, the SROD trans is closest to your current one, but will handle less torque than the above transmissions. The above units all have the same input shaft style and will bolt to your bell.
Elgringo64
Aug 11, 2013 04:43 PM
volksrod1
Feb 1, 2007 06:41 PM
ras4434
Apr 12, 2006 11:46 PM
cbfomoco
Sep 17, 2005 01:39 PM
Boss300
1966 - 1977 Early Broncos
May 13, 2002 08:40 PM
