Sponsored by: Real Truck
Timing Chain
Old Jun 15, 2010 | 09:17 PM
dfboothe's Avatar
dfboothe
Timing Chain
Alright i've got a 1999 5.4L F250
so me and my dad had to change the oil pump and timing chains, since if/when someone took it apart before, they put the two chrank sprockets on the wrong way allowing the timing chains to wear together and tear one apart, which then made it back out and start eating away at the oil pump, the broken parts of the timing chain ended up in the oil pan and were clogging the oil pick up tube, now that we've changed all of the parts, we're having trouble getting the timing lined up, are the timing marks on the sprockets and chains just for lining up the initial timing? Will the timing marks be off after a complete rotation of the crank? even if it's timed right?
Thanks for any help, this has been giving us hell for the past two days.
Dylan
Old Jun 16, 2010 | 07:09 AM
Johnny Langton's Avatar
Johnny Langton
Dylan
Yes-that's exactly what will happen. Since the camshaft gear is larger than the crankshaft gear,as soon as you make one revolution-the chain's marks will not line up with both sprockets for many revolutions.
JL
Old Jun 16, 2010 | 09:13 AM
dchamberlain's Avatar
dchamberlain
2 complete turns of the crank should equal 1 complete turn of the cams.
Old Jun 16, 2010 | 09:18 AM
Johnny Langton
Yes,but that WILL NOT have the chain's "copper" links lined up again in just 2 revolutions.
JL
Old Jun 16, 2010 | 09:44 AM
dfboothe's Avatar
dfboothe
thanks guys
this has been frustrating, we thought it would line back up after a rotation
this forum is the best
Old Jun 16, 2010 | 03:46 PM
mwsF250's Avatar
mwsF250
Yup, it will take MANY MANY rotations for the marked links to line up again.
After we set them using the colored links, I counted the number of "pins" between crank and cam marks so I could double check timing after we rotated the engine.
Old Jun 23, 2010 | 10:50 PM
lanman's Avatar
lanman
I've read somewhere that it took either 52 or 54 revolutions of the crank to get the links to line up again. Don't know if thats true but given how long those chains are, I believe it. I know they don't line up after just a few turns for sure.
MoJensen87
Aug 6, 2014 02:02 PM
jetrinka
17
Dec 19, 2012 10:25 AM
Badfunkn
Apr 26, 2012 02:21 PM
Jim88554
1997 - 2003 F150
Nov 17, 2008 05:39 AM
dgrant09
Apr 20, 2008 04:06 PM
