Power steering
Old Jun 15, 2010 | 08:12 PM
tbirdage's Avatar
tbirdage
Power steering
Hey guys, I just got my truck back on the road after 4 months of extensive body work and I'm noticing the power steering is almost none at idle while sitting still. If I gouge the go pedal, it seems fine. The tires are 315s. It's really a PITA to move around and was hoping y'all could give this some thought.
Old Jun 15, 2010 | 08:18 PM
zx250's Avatar
zx250
Of the next Riffraff East
Make sure you have enough fluid. Might be a good time for a pump flush with fresh ATF.
Old Jun 15, 2010 | 11:33 PM
jcrammell's Avatar
jcrammell
Hey Stu flush out the power steering pump with some syn mobile one or something comparitive. My steering feels totally different since I did mine. Very easy and quick.
Old Jun 15, 2010 | 11:36 PM
snakedoc's Avatar
snakedoc
X3..............
Old Jun 15, 2010 | 11:53 PM
big poppa's Avatar
big poppa
X4, what the guys said...If a pump could say ahhhh, it would, so much better.
Old Jun 16, 2010 | 02:12 PM
tbirdage's Avatar
tbirdage
What is X3/X4? Can I get it at a parts store? How much will I need? How do I flush the system thoroughly? Thanks!
Old Jun 16, 2010 | 04:01 PM
clintbonnie's Avatar
clintbonnie
X3 and X4 means the guys just saying they too agree with the previous post... I did my flush with two quarts..
here is how you do a flush and chg and fluid.. auto zone has the mobile 1 "syn" mercon AFT.. (don't use power steering fluid)
Ford Super Duty Power Steering Flush | Superdutypsd.com
Old Jun 16, 2010 | 04:50 PM
dm ford rebal's Avatar
dm ford rebal
try a new ps pump i put one in and now its great
Old Jun 16, 2010 | 05:32 PM
clintbonnie
Check the tire pressure also .. after sitting, the pressure may dropped..
Old Jun 16, 2010 | 09:23 PM
Bossman7121's Avatar
Bossman7121
Frond damage and did they remove / replace the ps pump? Maybe they put in power steering fluid instead of Transmission Fluid. Dump and replace, check tire pressure etc...
Old Jun 16, 2010 | 09:44 PM
tbirdage's Avatar
tbirdage
Oh, ten 4 on the X3/X4...lol, I was like WTF! Good call on the tire pressure too. I did all the body work myself, no mechanical damage but the driver's side sheetmetal was eaten slap off my truck by some trees and a sideways skid. Thanks again, I'll do the flush and TP check tomorrow and will check back in on here.
Old Jun 17, 2010 | 10:58 PM
tbirdage's Avatar
tbirdage
BAM! Fluid flush with mobil 1 syn and it's good as new! I had a small whine in the pump when I started and I heard it disappear. Thanks again Enthusiasts for fixin' my truck! I'm doing brake fluid flush in the morning since I now am a firm believer in fresh fluids.
Old Jun 17, 2010 | 10:59 PM
clintbonnie
Congrads.. Stu... Love it when a plan comes together..!!
Old Jun 17, 2010 | 11:02 PM
clintbonnie
You should look in to getting some "speedbleeder" It sure makes changing brake fluid easy..
SEE: Home
Old Jun 18, 2010 | 08:58 AM
Rick2001's Avatar
Rick2001
I recently had my power steering flushed. It greatly improved the steering as well as braking response.
