Sandblasting out rust...
Old Jun 15, 2010 | 07:28 PM
bkohne1's Avatar
bkohne1
Im going to start blasting my truck soon and i have a couple questions. Once im done sandblasting do i need to sand the area before i add filler (if needed) or prime the area?
Old Jun 15, 2010 | 08:32 PM
Diesel_Brad's Avatar
Diesel_Brad
No. The sand will have etched the area enough for body filler to stick.
Make sur when you are sandblasting you don't go over 60psi and keep the nozzle at a 45* to the panel being blasted, otherwise you risk warping the panel
Old Jun 16, 2010 | 08:16 PM
bkohne1's Avatar
bkohne1
How do I know if i need to put filler on the blasted spot. Besides obvious pitting or holes. I have alot of surface rust that is really light in some places.
Old Jun 16, 2010 | 08:23 PM
zinke13's Avatar
zinke13
I'd use some rust-mor and the areas that may have had rust after you're done blasting incase you don't get it 100%. Any auto paint shop should have it or a similar product.
Old Jun 16, 2010 | 08:59 PM
Diesel_Brad
If it is pitted ,it will need something to fill the pits, if filler prime will not fill em then you will need to use a filler of some varity
Old Jun 16, 2010 | 09:08 PM
hasteranger's Avatar
hasteranger
if you have a lot of rust pits you might wanna try several thick coats of a filler/primer. it will really cut down on the amount of filler you need to apply. You will need to long board sand the truck... I'd get a jitterbug.
F1Jayhawk
Sep 11, 2011 04:23 PM
Colt65
Oct 1, 2010 02:10 AM
F250FarmBoy
Paint & Bodywork
Jun 21, 2007 10:13 PM
karljay
Paint & Bodywork
21
Dec 29, 2001 08:11 PM
