engine ID...need some help
Old Jun 15, 2010 | 06:22 PM
hghgrad's Avatar
hghgrad
I was informed by the PO of the 1988 f250 that I just picked up that the motor was swapped for a 302.
Now, as that seems odd, I decided to check out some things for myself. It seems that it has 351 manifolds on it. The lower bolt on the thermostat housing is well clear of the water pump. There's a rib if I stick my hand directly behind the distributor. I have read that these are sure signs of the 351...but the only sites I have found are for classic mustangs ect.
Am I correct in thinking that this is a 351 and that the PO had no idea what he was talking about? Is there any sure fire easy way for me to check?
Thanks in advance, I'm new to older fords...
Old Jun 15, 2010 | 06:37 PM
nflfreak43's Avatar
nflfreak43
look at the upper intake. it will have lil "runners. if they are squarish its a 302. if they are rounded its a 351W.
this is the easiest way to tell. or you can take a tape measure and measure the width of the lower intake. if its 9.5 inches its a 351W. if its 8.2" its a 302.
Old Jun 15, 2010 | 07:34 PM
hghgrad's Avatar
hghgrad
The runners on the upper intake are round/ovalish. Guess it's got a 351w then?
It didn't seem like a dog at all when I test drove it. Should have guessed that he didn't know what he was talking about.
Old Jun 15, 2010 | 08:03 PM
danr1's Avatar
danr1
Doesn't it say 5.0 or 5.8 right on the top of its upper intake?
If not isn't the 5.0 the only one with the removable plate that states its size? or does that only pertain to the car intakes?
Old Jun 15, 2010 | 08:06 PM
hghgrad's Avatar
hghgrad
It only says something about fuel injected. No listed engine size.
Old Jun 15, 2010 | 08:15 PM
danr1's Avatar
danr1
Huh, mine says 5.8 on it, buddies bronco and Lincoln both say 5.0 IIRC, just figured they all did.
I remember the plate that said 5.0 on his Lincoln was removable but do not recall if the bronco is, the 5.8 its formed right in with the casting of the intake itself.
Old Jun 15, 2010 | 08:21 PM
hghgrad's Avatar
hghgrad
Just found another clue, something about 302 EGR coming from lower intake and 351 coming from passenger exhaust manifold. Another check in the 351 box
I'm considering taking the upper intake off and measuring if the weather is decent tomorrow. I'm missing the passenger side exhaust manifold now anyways, so it's not like I'm going to be driving it anytime in the next few days.
Old Jun 15, 2010 | 09:13 PM
nflfreak43's Avatar
nflfreak43
the older intakes didnt have the engine sizes labelled on them. thats why i gave the tips to figure out how to identify it.
Old Jun 15, 2010 | 09:20 PM
nflfreak43's Avatar
nflfreak43
when you do this you might as well go ahead and pull the lower after you measure and replace those gaskets and replace the valve cover gaskets as the valve cover gaskets are prone to leaking. and replacing the lower intake gasket lets you get a chance to look into your oil galleries. and see how much gunk is in there. and also you'll be able to see the LONG LONG pushrods on a 351W...
here they are on the 351W im building. ive got it down to the bare block waiting to take it to the machine shop....
Old Jun 15, 2010 | 09:29 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Isn't the fireing order on the 351 (1-3-7-2...) as opposed to 302 (1-5-4-2....)?
Old Jun 16, 2010 | 08:13 AM
hghgrad's Avatar
hghgrad
I definitely have some leaks at the valve covers. Maybe I'll pull it all apart and get those changed out while I'm in there.
Gotta get a new exhaust manifold ordered up so I can drive this thing.
Old Jun 16, 2010 | 03:55 PM
nflfreak43's Avatar
nflfreak43
yeah just get some rubber gaskets not the cork ones. the rubber ones are better.
Old Jun 16, 2010 | 05:04 PM
hghgrad's Avatar
hghgrad
I pulled the upper intake off and found a casting number on the lower. Looks like it's a 351w.
This helps out a lot. When I go to sell it down the road, it'll be easier to positively say that it's a 351 in this monster (Ex cab, long bed, 4wd)
Old Jun 16, 2010 | 06:01 PM
nflfreak43's Avatar
nflfreak43
yep. i forgot to mention that. dam the one thing that tells it plain and simple i forgot.
oh well glad to help.
rieper
16
Mar 27, 2018 08:16 AM
robin1t2002
1997 - 2003 F150
Apr 23, 2012 10:29 AM
mudder460
Sep 16, 2009 05:11 PM
fredo181
Modular V10 (6.8l)
Sep 15, 2009 10:08 AM
tmartinford
New Member Introductions
Apr 2, 2007 01:43 PM
