power mirrors ain't workin'...
Old Jun 15, 2010 | 01:34 PM
The Oldtimer's Avatar
The Oldtimer
They quit a while ago...I've just been too lazy to ask for help, advice, or suggestions...!!!
04 FX4.
Anyone else have this problem?
Old Jun 15, 2010 | 01:51 PM
CCBennett_1's Avatar
CCBennett_1
I have the same problem. Mirrors, Pedals and Drivers seat. Supposed to be a wire between the fuse box and the seat that is broken but I wasn't able to locate it. I haven't had time to remove seats and carpet if need be so it is still broken. Luckily it broke with my seat in the right spot for me.
Old Jun 15, 2010 | 05:08 PM
The Oldtimer
The adjustable pedals and the power seats work just fine. I am wondering if the control lever doohickey on the armrest is the culprit...???
Old Jun 18, 2010 | 11:45 AM
FordMasterTek's Avatar
FordMasterTek
The wire you are looking for is orange the location is passenger floor sill plate remove it. remove the c-pillar floor or kick panel passenger side open the sleeve that contains the wire loom follow the loom up towards the fuse panel you will find a 3 into one splice ( 3 orange wires into 1 orange wire) pull the splice apart sometimes that oranange wire in on the bottom of the loom look good its there...
the splice is corroded inside causing these issues sometimes mirrors sometimes mirrors seats,pedals
solder the spice together all will be good
sorry no pics available
Old Jun 18, 2010 | 09:30 PM
Wilber15's Avatar
Wilber15
The wire is Orange w/ a green chaser if i remember correcty?
Old Jun 19, 2010 | 02:14 AM
The Oldtimer
Thanks for the info..I will check it out and let you know if that did it
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
