can I???
Old Jun 15, 2010 | 12:42 AM
thabble's Avatar
thabble
can I???
i'm lookin at a 90 f-350 4 door dually with a 7.3 international...i'm not sure as to the specs on it and am curious about that and whatever you can tell me there could be a great help but i'm also curious about turbo upgrades...can i pull a turbo off of a international 2+ ton truck and put on the f-350 and what would be the pro's and con's there? thanks any help would be greatly appreciated.
Old Jun 15, 2010 | 01:05 AM
LCAM-01XA's Avatar
LCAM-01XA
Well does the 2-ton IHC truck have an IDI engine in it? Cause AFAIK those were never turbocharged from the factory when used in medium-duty trucks, so if that's the engine in it and there's a turbo on it then it's an aftermarket setup of some sort and should swap over to the F350. If the engine is a 444E or a DT446 or a DT360 then the short answer is no, the turbo will not fit the F350 engine without some fabrication.
Old Jun 15, 2010 | 01:08 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
International Harvester IDI - Wikipedia, the free encyclopedia
7.3 L IDI Specifications:
Manufacturer: International
Production Years: 1988-1994
Applications: Ford F250, F350
Configuration: V-8
Block/Head Material: Cast-iron/Cast-iron
Displacement: 444 cubic inches, 7.3 Liters
Compression: 21.5:1
Bore: 4.11 inches
Stroke: 4.18 inches
Injection: indirect injection (IDI)
Aspiration: naturally aspirated, non-turbo (turbo version 1993-1994)
Weight: 920 lbs (approx)
Peak Horsepower: 185 HP @ 3,000 RPM (190 w/ turbo)
Peak Torque: 360 lb-ft. @ 1,400 RPM (388 w/ turbo)
Reputation: Reliable, later became 7.3 Power Stroke
Additional 7.3 L IDI Information:
* Though the 7.3 L IDI and 7.3 L DI Power Stroke share the same displacement, the engines are ultimately very different
7.3 L IDI Diesel Specs & Information
the IDI's may not be a powerhouse in today's standards,but us owners totally love them,mainly because they are VERY simplistic and compared to today's diesels,they cost pennies on the dollar to maintain.
very reliable engines,with many owners claiming well over 300,000 miles on theirs along with many claims seeing up over 20 mpg at times.personally seeing an average of about 16 mpg with mine,hauling heavy loads with a large enclosed stake body.
if your looking for a low cost diesel rig with plenty of pulling grunt,it really is hard to beat a nice maintained 6.9 or 7.3l classic IDI in my opinion.
i sure love mine.
Old Jun 15, 2010 | 08:05 AM
thabble's Avatar
thabble
thank you sir, that's what i was hoping to hear...i need that kind of fuel mileage and vehicle life if at all possible...
19-F250-78
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
20
May 15, 2013 11:41 PM
jacaroo
Jan 30, 2013 04:52 PM
Piolet
Dec 30, 2011 06:51 AM
