9.75 axle
Old Jun 15, 2010 | 12:32 AM
97 HD's Avatar
97 HD
9.75 axle
I need a quick rundown on how to replace an axle seal on the 9.75 rear axle. Is it the same as the 8.8?......basically remove cover, remove screw, remove pin, push in axle, remove c clip and slide the axle out, remove and replace seal and re assemble in reverse
Old Jun 15, 2010 | 04:47 AM
svt2205's Avatar
svt2205
I believe so, don't forget that you have to pull the rotor and caliper too.
Old Jun 15, 2010 | 09:34 PM
Peter94's Avatar
Peter94
Be sure to thouroughly clean any brake pads/rotors of any grease, and also stock up on L/S additive if you have one in your truck. Otherwise it is EXACTLY as you stated.
Old Jun 16, 2010 | 01:00 PM
97 HD's Avatar
97 HD
Job done. It was that easy.
Toplait
1997 - 2003 F150
Oct 2, 2014 11:57 AM
Welder Guy
1997 - 2003 F150
May 29, 2012 08:23 PM
cledusdtrucker
1997 - 2003 F150
Oct 17, 2010 08:03 PM
IronMiner
1997 - 2003 F150
Jul 26, 2007 02:05 PM
