Are all E4OD's the same??
Jun 14, 2010 | 08:32 PM
I found one with 89k on it from a 96 F350 on CL.
Will it bolt up to my 94 5.8 Econoline?
Will I need a application specific TC?
Jun 14, 2010 | 08:40 PM
If the E4Od is from a small block it will bolt up. If it is from a big block or a diesel it will not bolt up. If it is from a 4x4 it will not bolt up.
The torque converter is application specific.
Jun 14, 2010 | 09:08 PM
"Torque Converter
There are 4 different converters for the E4OD. The difference between them is damper spring rate, converter stall speed, and mounting type.
Ford uses a letter code (stamped on the converter lid) to identify the differences.
Type 1
Letter Codes: A,B,G,L,N,O, T, and U
Engine: 4.9L and 7.5L Gas
Stall Speed: LOW
Mounting Type: 4 Studs
Description: 13" dia. w/ 1.375" pilot with converter clutch
Type 2
Letter Codes: E, F, M
Engine: 5.0L and 5.8L Gas
Stall Speed: High
Description: 13" dia. w/ 1.375" pilot and converter clutch
Type 3
Letter Codes: C,J,K,R
Engine: 7.3L Diesel
Stall Speed: Low
Mounting Type: 4 Studs with re-inforced welds that are longer in length
Description: 13" dia. w/ 1.375 pilot and converter clutch
Type 4
Letter Codes: I.D. by use of 6 mounting studs used in 1996 and up.
Engine: 7.3L Diesel
Stall Speed: Low
Mounting Type: 6 studs with re-inforced welds that are longer in length.
Description: 13" dia. with 1.375" pilot and uses a double-sided converter clutch."
Jun 14, 2010 | 11:35 PM
Jun 15, 2010 | 05:03 AM
Thanks guys,
Beers are on me.
Jul 8, 2010 | 05:01 AM
Jul 8, 2010 | 06:35 AM
That should bolt right in.
Jul 9, 2010 | 04:39 AM
I hope so.
I haven't found too many honest deals on craigslist. I get burned half the time.
12gaugeCharlee
New Member Introductions
Jan 24, 2018 10:05 PM
Jaime74656
Dec 25, 2015 08:53 AM
wpnaes
Jul 15, 2013 09:18 PM
Trulyvintage
1947 and Older Ford Trucks
May 20, 2011 10:40 AM
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
300 ,
351 ,
73 ,
alabama ,
clutch ,
converters ,
coverters ,
craigslist ,
difference ,
double ,
e4od ,
engine ,
stall ,
stalling ,
transmission
