c6 is slipping
Old Feb 5, 2003 | 08:07 PM
DrFord's Avatar
DrFord
Question c6 is slipping
I recently swapped out a c6 tranny in a 78 ford with a 351M. This new tranny has started to slip. I have checked the fluid and it seems to be good. i even added a little extra in case the dipsticks were different. what can I do to fix this problem. how can I adjust it??
Old Feb 5, 2003 | 08:43 PM
RoadRash's Avatar
RoadRash
c6 is slipping
If it is slipping from 1st to 2nd or 3rd to 2nd, you may need to adjust to the intermediate band. If it is slipping while still in first that is most likely internal clutches, which may require a rebuild to solve.
