Sponsored by: Real Truck
Which module holds key programming?
Old Jun 14, 2010 | 03:51 PM
Corvette95's Avatar
Corvette95
Which module has to be programmed when both keys are lost?
Thanks!
Old Jun 14, 2010 | 05:01 PM
dchamberlain's Avatar
dchamberlain
It depends on the year and model of the vehicle.
Old Jun 14, 2010 | 06:03 PM
Corvette95's Avatar
Corvette95
Ooops, thought I had that saved in my signature.
08 F250 Diesel
Old Jun 14, 2010 | 07:05 PM
ReAX's Avatar
ReAX
Until someone more knowledgeable jumps in. I would suspect it's the GEM, which handles the body computer stuff. Ford did have another module, but I'm not sure the HEC module stayed around with the CAN upgrade.
Old Jun 14, 2010 | 07:27 PM
dchamberlain
I'm not entirely sure about anything beyond '07 myself. I do know that the GEM went away at least by '04. It was replaced by more function specific modules like the Vehicle Security Module (VSM) that controls door locks, keyless entry, the keypad and stuff like that, and others.
I have read on FTE references to a Remote Access Personality module.
I'd guess that you're looking for either the VSM or the RAP. I also believe I've read on FTE that programming PATS keys requires two other PATS keys, or it has to be done by the dealer.
Old Jun 14, 2010 | 07:40 PM
ReAX's Avatar
ReAX
2 keys to program a third is a security feature, that way little johnny can't dube a key and steal your vehicle that easily. Most all manufactures and programmable key securities should work along the same lines.
I don't know about the RAP, but in the earlier versions the VSM mostly handled door locks and dome light functions (particularly in 2002 which I had an issue with). Kind of like a keyless entry computer.
Old Jun 14, 2010 | 08:08 PM
Corvette95's Avatar
Corvette95
thanks. I know there is a seperate module that mates with the key transponder when both keys are lost. I tried to get a Helm manual but they were out of stock
