Sponsored by: Real Truck
Door Ajar Light
Old Jun 14, 2010 | 07:22 PM
Okapeekthegreat's Avatar
Okapeekthegreat
Door Ajar Light
My door ajar light is always on and never goes off. My doors are shut fine and its still on. I've searched on here and i have tried the wd 40 thing and nothing happened. Does anyone know how to fix this.
Its a 2001 f250 5.4 extended cab 4x4.
Old Jun 14, 2010 | 07:33 PM
conger's Avatar
conger
You may have to pull both of the door latch switches out to test them. I think they are simply a series circuit that needs to become a closed loop for the light to be off. When you open either door it breaks the continuity of the loop and turns the light on. You could probably find a wiring diagram in a Haynes book. More than likely your dealing with a bad door latch switch.
Old Jun 14, 2010 | 08:29 PM
drey04's Avatar
drey04
I replaced the switch in my driver's side door on my extended cab about 3 months ago. It's probably your driver door since that one is mostly likely opened and closed the most.
GTBksRule
Electrical Systems/Wiring
Apr 22, 2013 01:47 PM
socalarcade
1983 - 2012 Ranger & B-Series
Dec 12, 2010 05:17 PM
TampaDave
May 5, 2010 05:04 AM
rangergolfer
Dec 2, 2007 04:07 PM
Gcourville
Jan 2, 2004 06:45 AM
