Timing Chains (& you!)
Old Aug 30, 2010 | 03:43 PM
lew52's Avatar
lew52
Never seen nylon coated distributor gears ?? I have seen nylon coated cam timing gears ...Lew
Old Aug 30, 2010 | 09:37 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Nylon teeth on stock big block timing gears too...
When they fall apart it's time to pull the pan and get all that junk out of the oil pump pickup.
I just put a timing light on and snap the throttle open and closed.
If the marks jump around you are seeing evidence of a sloppy timing chain.
Old Aug 30, 2010 | 09:47 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Good idea. Do you think if the spout plug was removed, it would demonstrate that condiition more pronouncedly or not?
Old Aug 30, 2010 | 09:51 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Same w/ me..
Old Aug 31, 2010 | 04:54 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
My truck just has a DSII system but I would thing with the computer removed from the loop there's no chance of it having any influence.
It's only reading the signal from the pickup in the distributor anyhow...
You need to remove the spout to check and set base timing anyhow, no?
As the revs drop back down a slack timing chain will never show a steady decrease of the advance.
Just do yourself a favor and install something like a true roller and you won't have to think about for well over 100k.
Old Aug 31, 2010 | 10:53 AM
Lonzo's Avatar
Lonzo
How much rotation on the distributor is too much using the rotor to turn it? This one moves about 1/2", i.e. the full width of the "blade" on the tip of the rotor.
Mine only moves slightly, not even 1/16".
tmcquaw
28
Sep 6, 2014 08:03 PM
89munchies
Engine Swaps
Apr 24, 2013 08:02 AM
PreciousOne
Dec 14, 2010 02:21 PM
kw5413
140
Jan 15, 2009 11:47 AM
HOTSPOT
27
Dec 26, 2008 09:19 PM
