Hello, New to Forum....I removed the front suspension from what I believe is a 72 f250. The vin plate was there but not the tag with GVWR and related info....The vin is F25YRN65053.....Any help would be great Ill need info while rebuilding front end and brakes...... Im restoring a 1966 Ford F250.
Got this from vinwiz.com:
VIN Format: 1961-1980 Ford truck
Decoding: F25YRN65053
<TABLE border=1 cellSpacing=0 cellPadding=1><TBODY><TR><TH>Digit</TH><TH>Usage</TH><TH>VIN</TH><TH>Decoded</TH></TR><TR><TD>1-3</TD><TD>Series</TD><TD>F25</TD><TD>F250 2WD pickup</TD></TR><TR><TD>4</TD><TD>Engine</TD><TD>Y</TD><TD>V8 360-2v 196hp 8.0:1cr</TD></TR><TR><TD>5</TD><TD>Plant</TD><TD>R</TD><TD>San Jose CA</TD></TR><TR><TD>6-8</TD><TD>Mod Yr/Mfg Date</TD><TD>N65</TD><TD>1972 (Mfg Feb 1972)</TD></TR><TR><TD>6-11</TD><TD>Sequential Serial #</TD><TD>N65053</TD><TD>N65053</TD></TR></TBODY></TABLE>
