VIN Breakdown
Old Jan 14, 2009 | 11:13 PM
Lvcrprts's Avatar
Lvcrprts
VIN Breakdown
Ok all you faithful Ford followers need some help with my vin just curious as to what it is and where it came from. VIN# F25HRC92001. All i know is that its a 68' F250 Camper Special with power steering and power brakes A/C and dual tanks with disc fronts. Thanks for any info provided.
Old Jan 14, 2009 | 11:44 PM
ColodadoFordBoys's Avatar
ColodadoFordBoys
first 3 are series code (F-150 F-250 F-350) The 4th engine code and it appears to be a 390! The 5th is the plant code which I don't have the info for at this moment possibly canada just guessing from some newer decoding I'm seeing but ? The 6th to the 11th are the consecutive unit # hope this helps its all I can tell ya at this moment!
Old Jan 14, 2009 | 11:56 PM
Lvcrprts's Avatar
Lvcrprts
Thanks for the info every little bit helps!!
Old Jan 15, 2009 | 07:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F25 = F250 2WD Pickup
H = 390 2V
R = San Jose CA Assembly Plant
C92,001 = 1968.
ColodadoFordBoys: No F150's till 1975.
If the truck was assembled in Canada, a C would take the place of the R.
Old Jan 15, 2009 | 02:21 PM
ColodadoFordBoys
My Bad I'm new at the 67-72 game I always had 73-79's! So please forgive me still learning! My Chilton manual which I refered to for this info said "R" was a canada code but like I stated earlier that was for a later model truck so I guess that is incorrect?
Old Jan 15, 2009 | 03:22 PM
NumberDummy
From the 1920's thru 1955, R refered to Richmond, CA.
Richmond was built in Model T days, was too small to assemble all the newer cars/trucks, so a new assembly plant opened in San Jose CA in 1956.
R then refered to this plant till it closed several years ago.
C is the Ontario Canada Assembly Plant that opened over 60 years ago and is still in operation today.
Old Jan 15, 2009 | 04:50 PM
ColodadoFordBoys
Huh I might have to go back and check my info again?
Old Jan 15, 2009 | 06:33 PM
72-F100-4V's Avatar
72-F100-4V
Numbers are the NumberDummy's game, he cant be beat!!
Old Jan 16, 2009 | 09:17 PM
Lvcrprts's Avatar
Lvcrprts
Numbers you are the man. Ok here's one, ignition switch with the round terminals instead of the blades so i can stop using my screwdriver and use a set of keys.
Old Jan 17, 2009 | 03:01 AM
NumberDummy
D1AZ11572C .. Ignition Switch (Motorcraft SW1054)
Still available from Ford / MSRP: $76.40 / FTEpqrtsguy.com price: $41.26.
Fits: 1968/69 F100/750 and 1970 F100/750 before serial # G90,001.
NOTE:
This switch may not match the switch your truck has now because it was a Ford campaign replacement.
The original switch used on these trucks was defective, shorted out and caught FIRE!
In 1970, Ford replaced the original switch with the one above.
However, there were NO mandatory recalls back then. Ford send out "campaign" letters to all the dealers notifying them of the problem.
It was then up to the dealer to notify the customers: Mailers were sent out, but some customers never received them.
This new switch comes with a pigtailed wire plug. The plug was installed on the switch, the pigtailed wires were spliced into the wire harness.
If there is no evidence of this, the switch is the ORIGINAL.
Old Jan 17, 2009 | 05:09 AM
Lvcrprts's Avatar
Lvcrprts
Love all the juicy tidbits you post too numbers, nice to know why a part is replaced.
Old Jan 23, 2009 | 08:28 AM
strokin0154's Avatar
strokin0154
I have a vin question as well numbers... F10YCD15982. Thanks
Old Jan 23, 2009 | 08:57 AM
NumberDummy
Welcome to FTE
F10 = F100 2WD Pickup
Y = 360 2V
C = Ontario Canada Assembly Plant
D15982 = 1968
Just because the truck was assembled in Canada, does not mean it was sold new there.
Last week I decoded another VIN, and all the codes from the Warranty Plate.
The truck was assembled in Canada, but was ordered from the Atlanta GA Ford District Sales Office.
I posted this bit of info because I thought you'd like to know, seeing how you live in GA.
Look on your truck's Warranty Plate = third line for the DSO code. If it's 21, your truck was ordered from Atlanta.
The Warranty Plate is located on the left door face below the latch.
Old Jan 23, 2009 | 09:12 AM
strokin0154
What would signify a 4wd truck? This truck is 4x4, so I'm just trying to figure out if that is the actual vin for this vehicle or if maybe the door has been replaced.
Old Jan 23, 2009 | 10:06 AM
Fritolay's Avatar
Fritolay
f11 would be 4x4 look at the right hand frame rail between core support and cab original vin is stamped there.
