F100 first build -need some help
New to the forum but I have been getting alot of useful information from everyone.
I have a few questions on my 1979 F100 2WD with a 302. It currently has a C6 in it but its dead, so I was thinking of replacing it with a 88-92 AOD. From what I have read this is a good swap plus I can rebuild it later on to handle some serious power, I cant quite afford to do it right now. What should I be looking for when I actually do this swap? Will I need a new flexplate, driveshaft?
I do plan to do a total restoration on this truck, would it be possible to coat the frame with rubber undercoating with the body still on the frame? There is currently a 3 inch body lift on it that I will be taking out after I install the new transmission.
This truck needs alot of work so any tips or pointers for a newbie would be greatly appreciated.
Thanks in advance!
As far as an AOD, there are atleast 2 different lengths. The earlier ones do not require any electronics to shift. The crossmember will not line up and will have to move back a few inches. No big deal.
I am not sure about drive shaft length.
Engine balance changed so you need to run the flex plate that came with your engine or swap the harmonic balancer from a later engine if you swap flexplates.
You wouldn't happen to know the difference between a small bearing and a large bearing 9" axle would be? And what bearing are they referring to?
Thanks
Thanks
Basically, what I was trying to accomplish by swapping in a 4spd auto was to improve drivability and MPG's. I plan on building this truck into a cruiser and/or weekend warrior. Would it be cheaper just to get the C6 rebuilt for now? Does anyone know how much that would cost?
Thanks for the help everyone!!!
A wide ratio gearset for a C6
