Outside temp sensor
Old Jun 14, 2010 | 12:33 AM
ke6zmy's Avatar
ke6zmy
Outside temp sensor
I was in my '03 Ex today. It was well over 80 degrees outside. The in dash readout said it was 69. Then, at one point, it got as high as 71.
Does anyone know where the outside temperature sensor is so I can check it out?
How about where to find out what the reading should be on my ohm meter? And how to check it out? I would guess that different temperatures would read differently. Maybe it just needs a cleaning? A blast of air from a compressor?
Old Jun 14, 2010 | 07:59 AM
fordboy67's Avatar
fordboy67
The sensor is behind the grill, if I recall correctly on the drivers side. Mine had a wire about two inches long that corroded and was causing the same issues. It also affected the A/C on mine. once the wire was found and repaired, it worked again! Good luck.
Old Jun 14, 2010 | 09:00 PM
03-6L-X's Avatar
03-6L-X
Right in the same area where you would do the Zoodad Mod.
Might have to lift some rubber flaps to find.
suprdutyv10
May 29, 2023 02:18 PM
preppypyro
6.4L Power Stroke Diesel
Dec 14, 2016 01:03 PM
bridgeman
6.2L V8
Oct 19, 2015 09:57 AM
Fixnstuff
Sep 16, 2015 04:18 PM
cutlass
Jun 13, 2012 11:18 PM
