power loss
Old Jun 14, 2010 | 12:26 AM
firebug's Avatar
firebug
power loss
My 95 F350 has been running just fine, was driving the other day and the check engine light came on, power dropped off to only about 15 mph. Managed to get it to a mechanic shop. Code reader said cam position sensor and ICP (injector control pressure). Replaced both and the fuel pump that was leaking, still no power and still no ideas. Anyone ever have this problem or any ideas. Thanks.
Old Jun 14, 2010 | 03:40 AM
Oversize's Avatar
Oversize
Check your fuel pressure on you fpr see if its low, also check you fuel filter and FPR screen, any of those can cause similar problems. Does it smoke or do anything else weird right now?
Old Jun 26, 2010 | 02:43 AM
daveglass's Avatar
daveglass
My 95 F-350 was doing similar things, loss of power and rough engine up to 1800 rpms. I checked the fuel filter and it had fungus problems, I replaced it, but didn't help. I think one or more of the injectors must be clogged up, I have been running diesel kleen and other injector cleaners in it, still have the problem. Guess I will look at the fpr next, my fuel pump has good suction and pressure, guess it has to be the injectors.
Old Jun 26, 2010 | 02:48 AM
daveglass's Avatar
daveglass
samjen
Jan 25, 2015 02:03 PM
bulletproof6.0
Nov 14, 2013 01:44 PM
quietman
Mar 21, 2013 09:06 PM
Heff-7.3PSD
Feb 24, 2008 11:45 PM
castledrummer
May 2, 2007 02:59 PM
