Tips for setting wheel studs?
Old Jun 13, 2010 | 12:24 PM
mattphelan's Avatar
mattphelan
I'm in the midst of a brake job and bearing repack on my 96 F250 7.3L with Dana 50 Auto hubs. The forums got me this far, as Ive got the hubs out, bearings out, rotor removed from the hub assembly and now I'm attempting to reinstall the new rotor. I have pounded the studs back in through the rotor to the hub, but theres a small amount of play between the two. I've used an air hammer to try and set them further, sledge and nail punch, etc, and they seem as though none of them will set any further.
Is this normal for the connection between the hub and rotor to have slight play. When I say slight play, you cant see a gap between the two, but you can jiggle the rotor a tiny bit .
Just seems like this connection should be tight as can be.
Note: I also tried putting the lug nuts on and tightening them down with all I've got to 'pull' the studs the last little bit, to no avail.
Any help is greatly appreciated.
Old Jun 13, 2010 | 01:14 PM
jleal_21's Avatar
jleal_21
i hit mine with a big punch and a hammer until there was no more jiggle. u can also try tightening it with the nuts backwards(with the flat side down).
Old Jun 13, 2010 | 01:41 PM
427 fordman's Avatar
427 fordman
I had the same issue, used a big punch too and got it tight. Don't want them loose.
Old Jun 13, 2010 | 02:24 PM
Talyn's Avatar
Talyn
I've always been taught to use a nut to press them in.
throw on a washer and a nut with the impact wrench and suck them in.
Thats how I was taught.
Old Jun 13, 2010 | 05:39 PM
mattphelan's Avatar
mattphelan
Damn, great suggestions and unfortunately I've tried them all to no avail. I'm gonna go get new studs and nuts and see if fresh'uns might be better.
Old Jun 13, 2010 | 10:19 PM
mattphelan's Avatar
mattphelan
Argh. Finally got it, but now have a new problem. After installing the bearing retainer nut (the one which requires the 2 3/4" socket) there is a "lock ring key" which has to be installed. It has a tab that goes inward towards the bearing into a groove in the retainer nut, then wraps halfway around it like a snap ring. I broke the damn tab off attempting to install it.
Any suggestions? Does the tab really matter?
Old Jun 14, 2010 | 05:39 AM
427 fordman
https://www.ford-trucks.com/forums/965179-help.html
Check out that thread. We just went through this discussion on it. Yes it matters, its a lock to keep the nut from backing off
iamvandemon
1997 - 2003 F150
Mar 11, 2015 11:01 AM
MackGuy
Sep 12, 2012 12:45 PM
jaserlet
Nov 9, 2011 03:42 PM
dfronek
Jan 26, 2011 05:13 PM
br223899
1983 - 2012 Ranger & B-Series
Dec 9, 2004 07:31 PM
