tourqe
Old Jun 13, 2010 | 11:02 AM
DND58's Avatar
DND58
tourqe
Can someone confirm?
Turbo pedestal bolts 18 ft/lbs
Turbo hold down bolts 35 ft/lbs
Thanks
Old Jun 13, 2010 | 11:27 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
The Ford Service Manual shows 18 ft/lbs on both, but I usually just go by feel on these.
Old Jun 13, 2010 | 12:52 PM
Pocket's Avatar
Pocket
The 35 ft/lbs spec comes from Garrett. You can use either Ford specs or Garrett specs. Me personally, I don't get oil leaks when I tighten the turbo hold down bolts to 35 ft/lbs, but I will get leaks if I leave it at 18 ft/lbs.
Old Jun 13, 2010 | 02:12 PM
DND58's Avatar
DND58
Thanks guys. Ped is in, and will go to 35 ft/lb on turbo. There was no gap on top between collector and turbo, couldn't feel all around so installed clamp loose. Hopeing for no leak.
