front crank seal issue
Old 06-13-2010, 10:36 AM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
I've had my t. cover off twice and replaced the seal both times. Because it is the '75 block, I do not have the pins to position the cover and seal on crank. I use the v. dampener for placement. I also install the sleeve over the v.dampener end. I have used two v. dampeners, thinking maybe one was bad. But still I can not stop it from leaking.
Seal was lubed prior to installation. Silicone was applied to keeper groove to prevent leakage. I've never had such probs with a seal before, and wonder if I am missing something. I use the Felpro kit.
Old 06-14-2010, 04:54 AM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
is it leaking through the rubber, or around the seal by the cover?
Blakshukvw
02-09-2017 06:14 PM
richter roxs
16
01-27-2017 08:08 PM
SEAL1
12-21-2011 03:45 PM
2003u45
02-02-2011 08:56 AM
F-250 restorer
15
04-04-2010 06:05 AM
Quick Reply: front crank seal issue
