harmonic dampener
Old Dec 16, 2016 | 01:52 PM
richter roxs's Avatar
richter roxs
harmonic dampener
I have A 1996 e150 5.8 , The harmonic dampener is shot and need a new one . The problem is that this year has a misfire sensor ring attached to the dampener and no one including ford makes them any more . The question is can I not worry about the misfire ring and install a dampener that does not have one .
thanks
Old Dec 16, 2016 | 06:17 PM
wirelessengineer's Avatar
wirelessengineer
I don't know what a misfire ring is, but I just replaced mine on my 1996 E350 5.8, and I just asked for the dampener at NAPA, and installed what they gave me. It looks the same, and the van isn't running any difference.
Old Dec 16, 2016 | 06:25 PM
richter roxs
did the dampener have a ring that looks like a four point star on it?
Old Dec 16, 2016 | 06:50 PM
wirelessengineer
No, nothing like that. Mine is the 350, not the 150, but it's the same engine. I would think the engine stuff should be the same.
Old Dec 16, 2016 | 08:25 PM
annaleigh's Avatar
annaleigh
This might be what you are looking for but I would call them first
DamperDudes.net (Americas Largest supplier of harmonic balancers)
perhaps part #F6TE-JA for the ring?
Do you think that "4 prong reluctor ring"/"star wheel"/"tone ring"/"4 point you are referring to is the pulse ring for the misfire sensor", could be pressed on to the damper? (all those different names I came across when reading different articles..)
Some threads that mention your part
https://www.ford-trucks.com/forums/9...-or-older.html
harmonic balancer 96 bronco. only fits 96. - Ford Bronco Forum
https://www.ford-trucks.com/forums/7...-balancer.html
https://www.ford-trucks.com/forums/1...r-w-obdii.html
does it look like this:
Old Dec 16, 2016 | 09:51 PM
annaleigh's Avatar
annaleigh
This might be the whole part number
F6TZ-6312-JA
Call for Availability
Bluebonnet Motors, Inc.
(830)606-8011
https://www.easyparts.com/Parts/Engi...ord/F6TZ6312JA
here is another thread that mentions your part
"you can find the balancer I posted pics of, you can just press the 4 tooth wheel off and press a 36-1 wheel on.(In the right location, of coarse.) That will give you a 28oz balancer set up for a 351 or a 347 stroker for DIS. The part number is F6TZ-6312-JA. "
28 Oz Balancer for 5.0L Stroker kit | Ford Explorer and Ford Ranger Forums - Serious Explorations
This probably will not fit but I would check with Number Dummy and see if it will cross over
http://www.ebay.com/itm/Ford-Mercury-Pickup-Truck-Van-302ci-Harmonic-Balancer-Damper-E4TZ-6316-A-NEW-OEM-/321811895163?hash=item4aed7bd37b
Old Dec 16, 2016 | 09:57 PM
wirelessengineer
Interesting. Mine has nothing like that.
Old Dec 16, 2016 | 10:03 PM
annaleigh's Avatar
annaleigh
I wonder if one of them, yours and his might be one that was produced at the end of the year and called a different year.. I think my 88 was actually built at the end of 87.. or maybe one is a CA emissions van or something like that?
I read a post that said 1996 OBD-ll F150's with 5.8 use this misfire sensor. Does yours have OBD-ll Wirelessengineer?
AH editing as I find info....
another post says: All '96 F150s under 8500 pounds were OBDII. F250s and 350s aren't. IS your E350 over 8500lbs?
Ok, It is a misfire sensor, not a crank sensor, and ties in with the emissions not the ignition system. the pics are from a 1996 F150 with a 5.0. The truck is a 96 built in 08/95 and has a distributor and MAF. with a relocated TFI.
http://i260.photobucket.com/albums/i...1/motor011.jpg
On this pic you can see the actual sensor location on top of the damper. It is covered with a metal shield.
http://i260.photobucket.com/albums/i...motor012-1.jpg
Here is a thread asking if it can be eliminated. If eliminated, will lit pass emissions, I don't know.
https://www.ford-trucks.com/forums/1...or-bypass.html
No damper but here is the misfire sensor itself
FORD 1996 E-150 5.8L V8 Ignition Ignition Misfire Sensor
http://www.rockauto.com/en/catalog/f...sensor%2C10767
Old Dec 16, 2016 | 11:51 PM
annaleigh's Avatar
annaleigh
you might call these guys too they also rebuild dampers
FOR3026B 96/ F6TE-JA
Product Code: FOR3026B
Availability: In Stock
Price: $123.75
Old Dec 16, 2016 | 11:56 PM
vettex2's Avatar
vettex2
Price: $123.75
Good Info
They do pre '72 motor mounts and driveshaft supports too!
Old Dec 17, 2016 | 01:33 AM
richter roxs
thanks all good info
Old Dec 17, 2016 | 07:04 AM
wirelessengineer
Bingo. That's it. Mine is the E350. It's got an OBDII port that has power to it, but it doesn't do anything. Out near the battery there is a proprietary Ford diagnostic port that actually works if you have the Ford machine that reads it.
Very confusing, as I usually take my van to a local shop for work, and they were trying to get info from the OBDII port one time, and of course it wasn't working no matter what they did.
Old Dec 17, 2016 | 11:29 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by richter roxs
I have a 1996 E150 5.8L .. The harmonic dampener is shot and need a new one.
The problem is that this year has a misfire sensor ring attached to the dampener and no one including ford makes them any more.
E8TZ-6316-B .. Harmonic Balancer Assy / Available from Ford.
1988/96 E & F150/350 & Bronco 351W / 1997 F250 H/D & F350 351W
Old Jan 27, 2017 | 05:33 PM
Rex Haislip's Avatar
Rex Haislip
I have 1997 Ford F250 4.9L 300-6 cylinders. It has a misfire ring called crankshaft position reluctor wheel with 3 points. Please, I need the product part number for it. I have harmonic balancer puller and I forgot to use it. I was using the 2 jaws puller and it broke my crankshaft ring that fits to the 594-391 harmonic balancer Dorman to my 4.9L engine. The ring simply install with 3 bolts to the back of harmonic balancer damper. It use special torx bits with hollow from AdvanceAuto.
Old Jan 27, 2017 | 05:52 PM
annaleigh's Avatar
annaleigh
This is just to get an idea of if your part looks like this or not. The fitment on this part says only for a 1996 4.9.
http://www.ebay.com/itm/Crankshaft-Pulley-4-9L-E150-E250-E350-Van-1996-New-/121723747684/?_ul=DO
