Sponsored by: Auxito
engine surge
Old Jun 12, 2010 | 12:34 PM
1421jason's Avatar
1421jason
engine surge
i have a 1997 f150 triton 4.6 at 65mph rpm goes from 1900 up to 2200 then back down over and over does anyone have an idea whats wrong? have replaced cam tensioners and sensors.
Old Jun 12, 2010 | 05:01 PM
Bluegrass 7's Avatar
Bluegrass 7
There is not enough info to work with.
1900 to 2200 rpm sounds like it's going into and out of overdrive, because once in a gear, the RPM won't move around that fast over that great a range, in one gear..
Try turning OD off and see what it does.
Cam chain tensioners should not cause it either.
Cam position sensor controls fuel injection timing.
If you feel a stumble in OD between 45 and about 60, it may be a coil pak if a 4.6 or a coil (cop) if a 5.4 motor.
