1999 expedition AWD
Old Jun 12, 2010 | 11:02 AM
mholden1966's Avatar
mholden1966
1999 expedition AWD
my 99 eb seems to be stuck in awd mode hard to turn acts likes its in 4h but the lights not on lights do work when switch is turned thanks for any input
Old Jun 12, 2010 | 11:30 AM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
Check the operation of the shift motor. It very well may have stuck. It is located on the drivers side of the t-case.
BTW, the '99 Expedition does not have All Wheel Drive (awd). It has a part time transfer case that is automatically shifted to 4wd HI when a difference in speed front to back is detected by speed sensors. AWD generally denotes a center differential and a car based platform with no low range gearset. The similarly correct term for a truck based platform, center differential and low range would be Full Time 4WD.
Old Jun 12, 2010 | 02:42 PM
alloro's Avatar
alloro
That's true, it has A4WD (Automatic 4 Wheel Drive.) With AWD there is always power going to each and every wheel. With A4WD there is power going to only the rear wheels until they slip, then power is also sent to the front wheels (automatically) for added traction.
Old Jun 13, 2010 | 11:58 AM
mholden1966
thanks
thanks for the info ive had a dozen 4x4s from 66 to 95 from stock to 12 lift with 19/44 this is my first electronic controled 4x4 just got it my new project
jmmranger
31
Aug 26, 2020 09:22 AM
Millinex
May 10, 2017 04:08 PM
Mikeman
Apr 3, 2016 10:57 PM
goatsauce
Escape & Escape Hybrid
Feb 12, 2016 06:12 AM
Ron94150
Jan 11, 2016 04:49 PM
