Weird Brake Troubles...need opinions
My '06 Expedition has been having some brake issues. It all started with what seemed to be warped rotors. I changed out the rotors and pads, and everything was fine for about 2 months, then it started feeling like warped rotors again.
I did'nt have time to fool with it, so I took it to a local shop. They blamed it on warped rotors, and turned them. Gave the car back, with the same symptoms. I took it to another shop, and had them replace the rotors. No luck, same symptoms.
Symptoms are as follows: vibration in steering wheel from about 60 down to about 40 mph when decelerating. Is there anything, specific to an expedition that I need to look for? Oh yeah, the second shop discovered that the first shop had left off the caliper clip on the passenger side. Could this have damaged the caliper? Any help will be appreciated.
Thanks,
Travis
Thanks,
Travis
Thanks for the response Redhorse.
I should have given more info. Its a 2 wheel drive. The tires were balanced, and rotated when the new rotors when installed. I even had them check the alignment. I haven't jacked it up yet to check for work joiints, or bad suspension, but the shop says they couldn't find anything. I'm stumped. I thought about the ABS, but wouldn't it throw a code?
Do you feel the vibration through the brake pedal as well? If just through the steering wheel then I'd think suspension.
Odd that the problem went away for a couple of months after you changed rotors and pads the first time.
Dunno about the ABS throwing codes. There's smarter folks than me than can chime in on that.
Redhorse,
You definitely feel it in the pedal. You can also feel a slight, slow pulse at a very low rate of speed as you slow to a stop. Kind of like the brakes are grabbing, and then slipping. I had the shop check the rear rotors, and they swear they're withing spec. The only other thing I could think of is the front pads. I went with ceramic pads.
Wow, the slow pulse at low speed sure sounds like warped rotors. Maybe check the runout yourself (you know, "If you want anything done right..."). A dial guage with a magnetic foot from HF would probably tell you enough about warp (low $$ investment too). I have ceramic pads myself but only for the last month. I have heard nothing but good news regarding ceramic.
What strikes me is that you said it was fine until 2 months later. The #1 problem I run into at these fly by night tire/brake/oil change/rotation shops is that they all use pneumatic tools that aren't calibrated to put your tires back on. You hear this reeeeeer reerrrrrr clackityclackity click click click click click on each lug nut.
They are wrenching the $%*& out of your lug nuts and likely causing them to warp permanently. When this happens, there is no amount of turning the rotors that will fix them. They are done. New ones will be needed.
*******edit* I see where they were replaced 2x, so I guess this is a rant! Do you notice it at all speeds? Like is it a slight vibration at 30 or none at all?**********
Best case is you can try and retorque to proper specs and see if it goes away. The others have some good ideas. This is just my guess/rant!
I could not have described my problem any better than tdhixon... and last night I had a flat tire and asked the shop to rotate the tires as long as they had the vehicle up. They did and the problem is gone. I've had 3 sets of rotors in the last 30,000 miles - hearing what tdhixon said each time.
I've been told it is a Ford issue on the Expeditions - the exteme heat. Not sure if that is bull or not.
