Head gasket
Old Feb 5, 2003 | 02:09 PM
STEVE1103's Avatar
STEVE1103
Question Head gasket
Have some water leaking from the front of the engine, looks like the head gasket, do the sixes blow head gaskets out like this, or does this sound like its cracked? Thanks
Old Feb 5, 2003 | 03:38 PM
mantta's Avatar
mantta
Head gasket
First, I would suspect your water pump is leaking, second I would look close at your hose connections.
Old Feb 5, 2003 | 05:16 PM
Ford_Six's Avatar
Ford_Six
Head gasket
Don't forget the t-stat housing. Frequently the nipple for the heater hose rusts out, and causes a coolant leak.
Old Feb 10, 2003 | 07:52 AM
STEVE1103's Avatar
STEVE1103
Head gasket
Checked again and it is leaking from the head gasket, going to try and retorque it down, will let it warm up first.
Old Feb 10, 2003 | 02:48 PM
bigbaddorsey's Avatar
bigbaddorsey
Head gasket
hey, i just got a piston rering kit for a 300, and now i dont need it. it has all the gaskets you would need and everything else to do a piston rering. would you be interested if your head gasket is shot?
