First Y-Block
Old Jun 11, 2010 | 01:29 PM
1996pwrstrk's Avatar
1996pwrstrk
First Y-Block
I'm attempting to revive a 64 F100 with a 292 ,I have 0 experience with Y-blocks .The truck has been sitting for a long time so I pulled the plugs dumped Marvel Mystery oil down every hole ,popped the valve covers and found a stuck valve soaked it down too. I let it set for a week checked it today the valve is free and turned the engine over by hand no problem hooked up a battery and nothing, pulled the starter it's rusted solid I have never seen this happen before . Where is a good place to find a starter?Name:  DSC01477.JPG
Size:  145.2 KBI thought it might be the same as a 6 cyl but it's not the same style.[ATTACH]Name:  DSC01482.JPG
Size:  148.8 KB[/ATTACH]
Old Jun 11, 2010 | 03:20 PM
1996pwrstrk
I've been doing some looking around and I think I'm going to try the starter out of my 62 223 ,every where I look the 223 & 292 starters are the same part .
Old Jun 11, 2010 | 04:42 PM
312's Avatar
312
that is not the right starter for your truck.thats a 65 up starter.i never tried to use one so cant say if it will work.
Old Jun 11, 2010 | 04:58 PM
1996pwrstrk
Thats what I thought but it was bolted in place. The starter off my 62 223 should work on the 292 right?
Old Jun 11, 2010 | 05:14 PM
59flatbedford's Avatar
59flatbedford
wow that starter looks nothing like the one that came out of my 59 292. like looks like a newer style standard ford starter. The one in mine has a big front shaft and the gear kicked in from the other direction or something ive never seen any thing like it. the easiest way to check would be to just put the two starters side by side and look at them. If the gear is the same size, tooth count, it has the same length front on it and it bolt up it should work no problem.
Old Jun 11, 2010 | 06:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
How many starter mounting holes, two or three?
If three, and the starter bolts on, the engine's been swapped. It could be a 221/260/289/302 or a 352/360/390, or?
If the distributor is in front of the carb, the engine has been swapped...for sure, because 292's have the distributor behind the carburetor.
While 223/292 starters are the same, there were two different types. One was used with a M/T, the other with an A/T.
Some 223/292 starters used an inertia Bendix Drive that has a HUGE coil spring mounted on its shaft. The pictured starter isn't one of them.
Old Jun 11, 2010 | 08:52 PM
charliemccraney's Avatar
charliemccraney
The Y starter mounts with 3 bolts.
Old Jun 11, 2010 | 09:12 PM
1996pwrstrk
It has three mounting holes and I know it's a Y block dist is in back I believe its the original 292. My 223 starter has the big spring you mention Bill they are both manuals so I will give that one a try. The truck has not really been messed with very much the wiring harnesses are all intact and not spliced and diced. The truck only had 3 owners 1 was a big company that used for the maintenance crew , then someone used it for some type of business , then the man I got it from. It's just been sitting for quite awhile , I will try to remember to copy the numbers so it can be decoded.
Thanks
Old Jun 12, 2010 | 03:15 PM
1996pwrstrk
The starter from the 62 worked and we got the old girl fired up.
Old Jun 12, 2010 | 05:24 PM
garbz2's Avatar
garbz2
FE starters fit 292s. Your picture is of a FE Starter.
The correct type is a pull Bendix type. But the FE starter will do the trick.
Garbz
Old Jun 12, 2010 | 07:32 PM
1996pwrstrk
Garbz
Thanks, the one I pulled out is junk it got full of water when it was sitting and rusted up bad it even looks distorted like it might have froze .I heard the same thing from Jeff (mechmagchn ) about the FE starters heres a little video of the old gal running .http://www.facebook.com/profile.php?id=1451478177&v=app_2392950137#!/video/video.php?v=1469607147441
Old Jun 12, 2010 | 09:12 PM
obsa's Avatar
obsa
I have seen FE starters used before on a Y-Block when the ring gear on the flywheel was worn enough to not engage. Since it engages the other side of the ring gear it would prolong use fo the vehicle until the ring gear could be replaced. By the way nice 9N in the background
Old Jun 12, 2010 | 10:40 PM
charliemccraney
Note that not just any FE starter will work properly on a Y. It needs to be for a '64 or earlier FE application. That's not to say that the later starter won't turn the motor over, but the tooth pitch does not match and can potentially lead to trouble if used as a permanent replacement.
Bran new gear reduction starters are available for the Y from Automotive Electric Services. I've used one for probably the past 5 years now. It's smaller, lighter, and doesn't need to be rebuilt once a year, when compared to stock.
Old Jun 14, 2010 | 10:52 AM
46yblock's Avatar
46yblock
I've used one of the Automotive Electric Services starters for the past 4-5 years also. Wouldnt go back to the bulky original.
Cobwebman
Jun 12, 2016 12:36 AM
chefcollins1
Vehicles for Sale
May 3, 2016 09:16 PM
stil190
Oct 26, 2010 10:35 AM
e william
Dec 3, 2006 09:23 PM
phoneman91
37
May 23, 2005 08:19 PM
